Old 10-29-2016, 04:11 AM   #1
rabbito
rabbito's Avatar
Straight pipe after cat rust
my cat? its rusted inside out..its making loud tinging noise when idle or accelerate...i was going nuts...i found some shops that does full exhaust but its $700...plus gains only about 5whp...i dont want their full exhuast cause i already have an aftermarket header...
anyways i went to HKS exhaust shop...supposly they do all kinds of exhaust modifications...paid $50 and they cut off the rusted part, replaced them with matching diameter straight pipe
noise level: sound increased to slight bumble bee noise..no, its not like honda vtec on straight pipe..
performance: some are arguing how they lost power but i didnt lose any hp..20161029_142159.jpg20161029_141815.jpg
Sent from my SM-J710F using Tapatalk
Cosmetic: Toyota red emblem
Old 10-29-2016, 12:53 PM   #2
SirDigby
Drives: 2007 yaris 3 door
but now without a cat your car will stink... like an old turd car
Old 10-29-2016, 12:55 PM   #3
rabbito
rabbito's Avatar
im running E85...smells like a fresh corn in the moring 😆😆😆😆
Old 11-02-2016, 03:17 AM   #4
jra
Drives: 2015 yaris L
If you remove the cat computer will give engine a richer fuel mixture, will use more gas and turn check engine light on. I think you can get ox sensors that will lie to computer to keep cel off but still may run rich.
jra is offline   Reply With Quote
Old 11-03-2016, 12:11 PM   #5
rabbito
rabbito's Avatar
im on E85...richer the better...👌
Old 11-03-2016, 12:25 PM   #6
we all breathe the air...put a cat back on
Old 11-03-2016, 12:50 PM   #7
rabbito
rabbito's Avatar
im running on corn oil...no polution here...😇
Straight pipe rabbito General Yaris / Vitz Discussion 2 10-23-2016 02:16 AM
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 08:02 AM
Benefits of Removing Cat and Running Straight Pipe? Nexus1155 Performance Modifications 68 03-29-2012 01:00 AM
2.5' First Cat Straight Pipe with Greddy Ti-C gwasabi Performance Modifications 15 03-01-2009 10:50 PM
Exhaust Pipe Size (Tamaņo del tubo de escape) carlosh Central and South America 11 08-02-2007 04:15 PM
