Old 05-17-2007, 09:19 AM   #1
Turbo&Auto
Turbo&Auto's Avatar
Drives: 07
Help with lowering
I'm trying to install my Tanabe DF springs, how do you remove the nut on top of the front struts??? I can get a socket on top but then I can't get the wrench on the socket to turn it. Help please if you can :)
Turbo&Auto is offline   Reply With Quote
Old 05-17-2007, 09:24 AM   #2
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
Have u tried the search button for a Tanabe DF DIY??
those search engines are powerful....
Old 05-17-2007, 09:25 AM   #3
Turbo&Auto
Turbo&Auto's Avatar
Drives: 07
Yeah, I just noticed the howto section. When I found the site thru google it took me right to a forum page and I didnt notice the YW front page with the easy link.
Sorry for the laziness. I'm BIG on forums so I know how annoying it can be when someone does what I just did. My bad...
Old 05-17-2007, 09:30 AM   #4
YamilR
YamilR's Avatar
Drives: Absolutely Red Liftback
Send a message via Yahoo to YamilR
You need a 19mm wrench
YamilR is offline   Reply With Quote
Old 05-17-2007, 09:52 AM   #5
Toymaniac
Adm.ClubYarisQuebec.com
Toymaniac's Avatar
Drives: 2007 Yaris Sedan Aero group
sorry but i just did mine and it was a 17mm for both top bolts...
the 19mm its the 2 lower one that are bolted to the hub...
the fist one on top i removed it with an impact gun
Toymaniac
2007 Yaris sedan Barcelona Red
TRD Swaybar
TRD Springs
Tanabe Strutbar
Toymaniac is offline   Reply With Quote
Old 05-17-2007, 12:51 PM   #6
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
I just used my fingers because I am so tough and strong.
Didn't I mention that I also know -everything-.
SPONSORED BY
Old 05-17-2007, 06:08 PM   #7
Turbo&Auto
Turbo&Auto's Avatar
Drives: 07
Reading that how-to helped alot. I saw something online about remove the wiper tray with the wipers and all, I just couldn't believe that was the way. BUT sure enough it was....It was a lot easier then I thought too!! :) 2 hrs for the total install.
Here it is:
Old 05-17-2007, 06:20 PM   #8
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
Out of curiosity did you start at the front, or the rear? Which springs did you use?
blacksan is offline   Reply With Quote
Old 05-17-2007, 07:25 PM   #9
Turbo&Auto
Turbo&Auto's Avatar
Drives: 07
I started with the front since I figured it would be the most tough.
Tanabe DF's.
Old 05-17-2007, 07:30 PM   #10
blacksan
blacksan's Avatar
Tanabe DF's.
That would be my approach. Get the crappy part done, and then move on to the easy stuff. I assume you spent most of your time on the front end? Where did you place your jack for the front end work? I assume you brought both tires off the ground at the same time?
BTW, Where are you located at in PA?
Old 05-17-2007, 07:33 PM   #11
brickhardmeat
Lonesome Cowboy
I put mine up on jack stands
Front was a little time consuming for me all that goddamn turning and spring compressing, won't be so bad putting in the coilovers.
SPONSORED BY
Old 05-17-2007, 07:40 PM   #12
blacksan
blacksan's Avatar
The only thing I hate about unibody is the lack of a frame! I always worry about crunching body work even though I use the designated jacking points.
Old 05-17-2007, 07:48 PM   #13
brickhardmeat
Lonesome Cowboy
I always try and push the car off the stands before I start.
Of course with this car you kind of feel like you will dent or break something whaling on it as mentioned by others.
SPONSORED BY
Old 05-17-2007, 07:52 PM   #14
blacksan
blacksan's Avatar
I assume that maneuver is an effort to cause a natural obstruction from drive buys whilst you are wrenching in "Big D"!
Old 05-17-2007, 07:55 PM   #15
YamilR
YamilR's Avatar
Yeah I'm wrong, I meant to say 17mm box wrench. It's being 6 months and 8000 miles later and they look even better once they settle
Old 05-17-2007, 07:58 PM   #16
YamilR
YamilR's Avatar
DIY
Here's the DIY by Chris07LB
http://www.yarisworld.com/forums/showthread.php?t=1096
Old 05-17-2007, 07:59 PM   #17
blacksan
blacksan's Avatar
So, now that your ass is sagin you are one with the force?
tanabe nf210 vs. TRD lowering springs?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 01-23-2012 11:00 PM
Lowering Springs - Questions ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 01-10-2007 08:21 AM
TRD lowering springs' and/or shocks' Ride Quality?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 08-29-2006 12:42 PM
HOLEY COW 674.75 to install TRD lowering springs dbaxter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 08-09-2006 12:40 PM
Will putting new lowering springs damage original shock absorbers in the long run? Joel Leong Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 06-07-2006 08:30 AM
