Old 12-07-2016, 11:52 AM   #1
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
installed an ACT clutch last friday
From my previous turbo tercel (and friends tercels), I have plenty of experience doing clutches on small Toyotas
The yaris was not much different. Just more stuff to move, or get out of the way. Took me most of a day, but a solid 3-4hours was just waiting on the flywheel getting machined. Then reassembly took longer as I was wire-wheeling all the bolts and applying anti-seize. Took me 1:45 to get the trans out & maybe 2.5 going back in.
ACT Clutch kit p/n# TS6-HDSS
Its their Heavy Duty pressure plate with a sprung, organic disc for excellent streetability. I ran the same PP, but a sprung 4-puck on my Tercel and that was excellent as well. Brand new Toyota flywheel bolts & fresh Amsoil synthetic 75-90 severe gear fluid.
And my cheap trick for removing slop in motor & trans mounts. Ive been doing this for YEARS with great success for street cars. Ive been running the torque mount on the Yaris for 4~ years 'filled'. Decided to 'fill' the trans mount too. Car ended up being quieter inside with less vibration (especially noticeable is when the AC cycles on, before it would buzz the car, now I almost do not notice it engage), go figure.
Overall I'm very happy. Pedal feel/effort has increased moderately (I feel like I'm driving a sports car now, lol). The biggest change for me, my old clutch was engaging at the top of the pedal travel, while this is just off the floor. So my shift timing needs to change at low speeds to not lurch the car. Its just a matter of getting used to it & adjusting my habits.
The clutch is rated to something like 240lbs ft of torque. Which gives me plenty of headroom for whenever I get the turbo on the car.
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 12-12-2016, 08:38 PM   #2
3cyltrbo
thanks for the write up, I've been thinking of changing to a lightweight flywheel and I've been looking into the different clutches to pair with one
3cyltrbo is offline   Reply With Quote
Old 12-12-2016, 09:38 PM   #3
dogsridewith
Drives: 2007 2-door hatchback
mystery fiber/elastomer pieces revive engine transmission mounts
i guess everyone else knows what the donor blue/orange thing is
some sort of hose?
Old 12-12-2016, 10:21 PM   #4
KimmoKekki
KimmoKekki's Avatar
Drives: Yaris T-Sport
Yep silicone hose
KimmoKekki is offline   Reply With Quote
Old 12-14-2016, 10:01 PM   #5
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Why isn't there a like button here?? =D
I've been running a stage 3 Clutchmasters on mine for over a year now. Firmer pedal feel, but holds up to a Blitz supercharger or a 2ZR just fine.
Old 12-16-2016, 10:36 PM   #6
malibuguy
Obsessed with 1.5L
some sort of hose?
Originally Posted by KimmoKekki View Post
Yep silicone hose
Yes sorry, its from an old silicone coupler from intake plumbing. I have so many laying around
-96 Tercel 4dr
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 10:42 AM
Aftermarket Clutch Q's tmontague Performance Modifications 5 03-05-2016 04:33 PM
need help on my 2008 yaris compress clutch susucosp DIY / Maintenance / Service 0 05-15-2014 03:48 PM
FS: NEW - WR header, 280°-10mm Catcams, ACT clutch disc - NEW speed1 Items for Sale by private party 17 09-23-2013 05:50 AM
possible clutch gone bad? DevilGirl DIY / Maintenance / Service 19 11-15-2012 06:29 AM
