Old 12-12-2016, 11:05 AM   #1
bronsin
bronsin's Avatar
Solve The Yaris Mystery!
My Yaris will be eight years old next April. For the first five years I kept the hubcaps on and the rust marks quickly developed where the vents holes were in the hubcaps. (see picture) I assumed that was because the metal was exposed to the elements. I also assumed the parts of the wheel that didint rust was because they were protected by the hubcaps.
When I left the caps off for good I figured oh well now the entire wheel will rust.
But after three years that hasnt happened!
Why?
Old 12-12-2016, 11:31 AM   #2
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Ha, weird.
On Instagram
On Wheelwell
Old 12-12-2016, 12:08 PM   #3
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
I guess the hubcaps are holding salty slush inside, against the wheel rim, rather than letting it fall away naturally.
Sent from my LG G2 with CM13 using Tapatalk
Old 12-12-2016, 05:28 PM   #4
MadMax
MadMax's Avatar
I believe we have a winner!
Old 12-12-2016, 06:56 PM   #5
jcboy
Drives: Sedan 07
Why?
Thats because a metal piece which have some parts of it exposed to air will rust the ones that arent. Its a usual galvanic reaction which gets sped by the part that salts are present in the water (or mud) that covers these parts (as mentioned), as salts speed up these galvanic corrosion.
Sent from my G9208SS using Tapatalk
Old 12-21-2016, 07:17 PM   #6
sh0rtlife
actualy the answer is simple....IV..yes the sun killed the exposed paint...its more common than you think, now the rest of the wheel has 8 years of being protected advantage over the rest of the wheel....some paints are less capable of handling UV
Old 12-21-2016, 08:44 PM   #7
It's very common to see wheels with hub caps turn like this. Takes more than 3 years for them to rust
Though, I haven't had a hub cap in 13 years.
Sent from my SM-G930W8 using Tapatalk
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Vacationed in Italy - Brought home a D4D diesel Yaris CTScott Photo-Video-Media Gallery 19 07-26-2012 03:13 AM
