Old 12-14-2016, 09:00 PM   #1
frank2005
Drives: Toyota Echo RS 2005
Echo smell fuel at start up ?
Hi,
Cold temp at start up strong smell of exhaust, In summer this smell is weak.
Cold disturbs combustion? The catalyst to function effectively
Must be warm?
some tell me is it normal don't worry.
frank2005 is offline   Reply With Quote
Old 12-15-2016, 12:22 AM   #2
If it smells in cabin, then you must have a leak.
Otherwise, cold start up and smelly exhaust, then , according to my knowledge, is normal.
Sent from my SM-G930W8 using Tapatalk
Old 12-15-2016, 12:39 PM   #3
zoidberg444
zoidberg444's Avatar
From what i understand when you start a petrol vehicle the fuel system runs in open loop until it reaches operating temperature which means it runs rich then when its up to temperature it switches to closed loop when the cars own sensors can give it the necessary information to control the fuel mixture. So a smell of fuel is to be expected on start up.
Sent from my SM-G900F using Tapatalk
UK to Nordkapp in a Yaris
Old 12-15-2016, 03:26 PM   #4
car runs rich until its up to operating temperature...
typically smell it when you back into your fumes or are downwind from your tail pipe. if you smell it in the cabin at idle without wind, you might have an exhaust leak somewhere
Old 12-16-2016, 08:07 AM   #5
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Sometimes a bad O2 sensor can cause an exhaust leak straight into the cabin vents. This happened to my car before the Yaris.
Open the hood with the engine running. If the smell is heavier in the engine bay than in the cabin, look for exhaust smoke coming from the manifold, including the sensor. Hope this helps.
Old 12-17-2016, 09:33 AM   #6
On cold starts the computer only uses the intake and coolant temp sensors and MAF sensor to make fuel calculations. In addition to that, the cat isn't functioning until it gets hot. That's why it smells very rich in the winter.
Have: A very fine Yaris Verso ... with a slight fuel smell issue. Jesper M DIY / Maintenance / Service 6 10-06-2016 02:01 AM
Car cranks but won't start after fuel pump replacement Lightrfire DIY / Maintenance / Service 33 03-10-2016 02:30 AM
Fuel Trim Readings and EGR valve tmontague DIY / Maintenance / Service 1 01-22-2015 12:28 PM
2007 Sedan suddenly won't start acyaris DIY / Maintenance / Service 12 12-08-2014 09:37 AM
(Cheap from ebay) Magnetic Fuel Saver sternz Fuel Economy Forum 24 05-11-2013 12:33 AM
