Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 01-20-2017, 07:34 PM   #1
xal
Drives: 2010 Yaris
Exclamation 2010 Yaris - Engine Quit While Driving
With 83k miles on it, I'm surprised (and really bummed) that while in the middle of an intersection, the engine simply stopped running. There's no water in the oil, put in a new battery & nothing.
No clicks or other signs of life.
Dealership claims it's "child proofed" with a kill-the-engine mode.
My code reader doesn't detect a problem. To this the dealership says only they can unlock it & reset the engine.
This sounds ridiculous, however, the cost to "reset the engine" makes it a good thing for the dealership.
Have any Yaris owners, pros, enthusiasts, mechanics seen this happen?
Suggestions and HELP Please!
Thanks
xal is offline   Reply With Quote
Old 01-23-2017, 07:56 AM   #2
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
Thats a bumer..
So it does not turn over? Is it manual or auto? Do you have lights on the dash ? Or is it like there is no power on some circuits?
ncp13 is offline   Reply With Quote
Old 01-23-2017, 07:34 PM   #3
CB900F2
Drives: 08 Sedan
do you have gas in the tank?
CB900F2 is offline   Reply With Quote
Old 01-23-2017, 08:14 PM   #4
CoryM
Drives: 2009 5-door, 5-speed
If it detected an incorrect key, and the antitheft tripped, it takes the Toyota scanner to clear it. I'm not saying that's the problem though unless there are antitheft DTCs saying it's locked.
Old 01-23-2017, 08:17 PM   #5
If you know of anyone who has techstream software near you, use it to pull any codes that the dealership can see. This would also allow you to reset anything.
I've never heard of the engine locking out randomly and needing to be reset. Did the dealership explain why this would even happen?
Old 01-23-2017, 10:00 PM   #6
SirDigby
Drives: 2007 yaris 3 door
yeah that's not a thing that happens. (engine reset) when you put the key in and turn it, does your immobilizer light come on/flash? I would lean towards the anti-theft components. do you have any aftermarket parts installed like a remote start or aftermarket alarm?
Old 02-19-2018, 07:48 AM   #7
hichamaziz
Drives: my car is the best
hichamaziz is offline   Reply With Quote
Old 02-19-2018, 08:05 AM   #8
dogsridewith
Drives: 2007 2-door hatchback
Does "child proofed" mean it has had some sort of aftermarket system added?
Old 04-20-2019, 05:19 AM   #9
ibrahim issah
Drives: yaris
my yaris crank not start,when you test coils 12v and grands only comes
ibrahim issah is offline   Reply With Quote
2010, 83k, dealership, frozen engine, yaris 2010
Yaris verso engine swap Decieved Performance Modifications 3 06-10-2015 08:51 PM
2010 Yaris 1.33 engine rattling Rocko855 General Yaris / Vitz Discussion 6 04-09-2015 08:44 PM
