Old 02-17-2017, 02:14 PM   #1
Pinchlite
Drives: 2007 yaris HB
Led bulbs no high beams(I thought) solved
These are the lights.
https://www.amazon.ca/NIGHTEYE-Headl.../dp/B01J7KJF0E
I thought the highbeams did not work(daytime test)and was relying on the dashboard blue highbeam indicator.From further reading this is what is needed to get the blue highbeam indicator back
Headlight Load Resistor Kit - H4 LED Headlight Bulbs
https://www.superbrightleds.com/more...ht-bulbs/2179/
Or this fix(scroll down)putting in resistor.Luckily I can get these around the corner and will try tomorrow.This is for a cruiser so not sure if it works for a yaris though.
http://www.fjcruiserforums.com/forum...m-circuit.html
(link to resistor for any Canadians)
http://www.thesource.ca/en-ca/tvs-an...ack)/p/2719018
As far as the brightness goes they dont appear as bright in the daylight.I think that is because of the color temperature?
I will see tonight how they look.
Hope this helps others.
Pinchlite is offline   Reply With Quote
Madison, WI meet feeler suckerface Great Lakes 8 09-20-2016 03:45 PM
Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal V70R_Blackbrick Cosmetic Modifications (Exterior/Interior) 26 11-27-2013 10:14 PM
Prius C / Yaris LED foglight bulbs cali yaris Off-topic / Other Cars / Everything else Discussions 1 06-15-2013 08:55 PM
Thinking about buying LED Light bulbs and Projector head lamp LA Yaris California 15 02-07-2010 03:12 PM
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 06:17 PM
