Old 04-10-2017, 06:57 PM   #1
wnavarro
Drives: 2009 Yaris sedan
Changing the fuel filter
Hi all,
I'm trying to find a good quality generic fuel filter for a 2009 Toyota Yaris base 1.5.
But after searching I could not to get it,
Can anyone tell me where I can get a exact fuel filter like mine or if I can't do it?
Do I have any cheap options?
I tried the autoparts stores and they tell me they only sell the fuel filter as the whole fuel pump for $300.00. I can't shell out $300.00 every 100,000 miles just to change out the fuel filter.
Can anyone please offer advice if there is that one fuel filter sold seperately like mine.
What brand?
Thank you for any help offered.
wnavarro is offline   Reply With Quote
Old 04-10-2017, 07:48 PM   #2
Is there any particular reason why you want to change it? Showing symptoms of being clogged, or you just feel like it should be a maintenance item? Unless some serious crap got into your tank, these filters are pretty much in there for life. Very few have needed to undertake the horrendous task of replacing one on thee cars.
Old 04-11-2017, 08:52 AM   #3
bronsin
bronsin's Avatar
Agree there is no requirement to change the filter. Nor does Toyota sell the filter without the pump .
It's supposed to be changed only if its clogged.
Old 04-11-2017, 09:06 AM   #4
The filter is essentially part of the pump unit. It isn't a service item.
Old 09-11-2017, 02:45 AM   #5
jayanathcg
Drives: Toyota yaris 2000 SCP 10
I am using Toyota Vitz 1.0L YOM 2000 / service chart shows to change the fuel filter ( after Fifteen Years) I havent even inspect it. Do I really need to change the Fuel Filter with the Pump
jayanathcg is offline   Reply With Quote
Old 09-16-2017, 04:40 AM   #6
Kubcat
Drives: 2006 and 2013
I replaced mine at about 80,000kms. In my service book it is listed as a replacement item every 80,000kms.
I just used an ebay one and it I am now up to 150,000kms.
Kubcat is offline   Reply With Quote
Old 09-18-2017, 05:42 PM   #7
Stabicraft
Drives: 2008 BLACK YARIS
I picked up a load of crappy petrol a while ago.
The beast ran like a sloppy lawnmower.
The pulled the tank and flushed the fuel lines.
I asked about the filter and if I needed to change it.
They said that they replaced it (its a big job) but they also said Id not have to change it again unless it clogged.
Apparently, while the vehicle is running, leave it alone.
This from a Toyota service centre
Stabicraft is offline   Reply With Quote
HELP: Swings but does not start after fuel filter replaced REV 2 11 DIY / Maintenance / Service 12 08-19-2013 01:38 PM
Fuel Filter caveatipse DIY / Maintenance / Service 27 12-28-2012 09:45 PM
Replacing fuel filter duke_afterdeath Middle East 28 07-12-2010 04:26 AM
Fuel Filter abbeyaris General Yaris / Vitz Discussion 35 03-22-2009 11:40 AM
