#1 |
![]() ![]() Drives: 07 yaris Join Date: Dec 2016
Sway bar end link question
Hey guys I had to get my sway bar links replaced at the garage. When they cut off the bad links (rust corrosion big issue here) and went to install new links the auto parts store gave them the wrong links. Can I drive my car safely for a few days with no links installed? I know the car will roll a bit more which I'm fine with for a couple days
You'll be fine. Just zip tie the sway bar up out of the way so it doesn't get caught on the control arm.
| Sway Bar End Links Help! | GiovanniVan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 03-02-2015 11:14 PM |
| Which rear sway bar? | IsLNdbOi | Performance Modifications | 46 | 11-05-2009 06:07 AM |
| front sway bar question | thom25 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 13 | 08-25-2009 07:54 PM |
| aftermarket front sway bar end links? | jookybanana | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 08-08-2009 11:26 PM |
| Sway Bar! | dngz | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 55 | 01-12-2007 03:31 AM |
