Old 05-17-2017, 02:50 AM   #1
m.flores.0928
m.flores.0928's Avatar
Drives: 2014 Yaris
3rd gen front sway bar
Looking at upgrading suspension pieces in my car (2014, 4 door US spec)
I can't find anyone selling front sway bars (stabilizer, anti-roll bar) for this car. I can find rear ones all day long, as well as other suspension and chassis bits, but no front sway bar. Whats the deal? Can anyone help me track down some?
Thanks!
m.flores.0928 is offline   Reply With Quote
Old 05-17-2017, 04:20 AM   #2
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Your car has a very good front sway bar from the factory. However Tanabe makes an aftermarket one as well as other suspension bits:
http://www.tanabe-usa.com/rnd/post/2...nderbrace.aspx
https://www.autohance.com/tanabe-tsb...FYKEswodrSYLgQ
Not worth it in my opinion. Rear bar yes. OEM front bar is more than adequate.
Old 05-17-2017, 11:22 AM   #3
m.flores.0928
Drives: 2014 Yaris
Thanks!
How is the front bar good enough? I feel a lot of body roll and front end push.
Old 05-17-2017, 11:31 AM   #4
Dabuu
Radical Dreamer
Drives: spiritedly.
Bigger front bar will increase understeer.
What suspension are you running right now?
Tires?
Trackday, autocross, or toogay run?
Cusco also makes a front bar.
Enjoy Family Car Sports
Dabuu is offline   Reply With Quote
Old 05-17-2017, 11:34 AM   #5
m.flores.0928
Drives: 2014 Yaris
Tires?
I'm in the beginnings of learning the basics of suspension tuning. When I get my budget up and running, i'm thinking about autocross.
I thought a bigger sway bar increases oversteer? What's the explanation on that?
Currently have factory set up except I have bigger tires (195/55/15) and spacers. 35mm rear 25mm front.
Old 05-17-2017, 12:05 PM   #6
NYC-SE
NYC-SE's Avatar
Read this thread:
http://www.yarisworld.com/forums/showthread.php?t=14026
Old 05-17-2017, 12:09 PM   #7
m.flores.0928
Drives: 2014 Yaris
Score, thanks!
Old 05-17-2017, 11:51 AM   #8
Dabuu
Radical Dreamer
Drives: spiritedly.
A bigger sway bar in the rear (or in our case, the addition of one) will increase oversteer by stiffening up the rear.
Basically, stiffer front will give you understeer and stiffer rear will give you more oversteer.
I'm no suspension expert, but that's how I understand it.
Throw a TRD rear sway bar back there, and you'll get more rotation in the rear.
Then some nice lowering spring/shock combo, sticky street tires w/ proper offset wheels and you'll be grinning at every corner.
Old 05-17-2017, 12:03 PM   #9
m.flores.0928
Drives: 2014 Yaris
Oh ok got it. Thanks!
I'm leaning on TRD springs right now, but I'm not sure how much they lower the car. I didn't catch it. Recommendations? Factory ones are too soft I think, especially in the rear.
Not sure about coilovers, I feel like I don't need the adjustability. I'm sure good ones are worth it but I feel like it's overkill for me. Thoughts?
Any recommendations on good shocks? Factory good enough? I feel like factory shocks are waaaay soft.
I have the spacers to mimic some sort of offset but I still don't know what's a proper offset wheel for good cornering. I can't tell a difference in that regard.
What about tire recommendations?I have Kumho tires they are pretty basic (don't remember the model) they were like $90 each just in parts cost. The shop I went used those because they were the only tires they had in that size I was trying to get. I figured wider is better for more road contact, but didn't want any taller.
chassis, stabilizer, suspension, sway
Which adjustable front sway bar endlinks work on the Yaris? marlondog Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 09-02-2011 10:11 PM
Sway bar link replacement salmonz DIY / Maintenance / Service 8 12-09-2010 10:30 AM
C-One Front Sway and 4 Point H-Brace ... SoCal DuckinOut Items for Sale by private party 3 09-13-2010 05:38 PM
front sway bar question thom25 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 08-25-2009 08:54 PM
Sway Bar! dngz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 55 01-12-2007 04:31 AM
