Old 05-31-2017, 12:15 PM   #1
xdarkxfirex
Drives: 2015 yaris le
Rusty brake line ends?
I noticed this last summer and recently working on the rear drum brakes. Most of the lines are coated in plastic, some of the ends were coated in green poly. The two long ones I had running to the back had some scaly rust at the end and I coated them last year in undercoating, and again with heavy grease to help preserve them. Anyone else notice this on there cars?
xdarkxfirex is offline   Reply With Quote
Old 05-31-2017, 02:20 PM   #2
I always coat my brake line ends in a fluid film anytime in in that area because of this. On any car I've owned the end that you put a wrench in get corroded pretty easily
Old 06-06-2017, 12:20 AM   #3
xdarkxfirex
Wondering if this is fine or I should just replace the ends. Dont plan on keeping the car long, getting another newer toyota.
File Type: jpg 18945111_1450542988324816_320523207_n.jpg (43.5 KB, 36 views)
Old 06-06-2017, 09:20 AM   #4
Those are fine. That is just minor oxidation there.
Old 06-06-2017, 09:32 AM   #5
^this
brake lines, coated, poly
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 09:50 AM
Zage Turbo Kit Install - Toyota Yaris Focus_Sh1ft Forced Induction Forum 160 02-06-2022 09:14 PM
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 09:05 AM
Anyone care to make a DIY on break flushing and bleeding? Hard_Yaris DIY / Maintenance / Service 19 05-04-2011 04:49 PM
SS Brake Line + Brake Pad + Rotor Installed~ AlainMikli Performance Modifications 45 03-20-2010 11:55 PM
