Old 06-10-2017, 10:57 AM   #1
CueBall
Ruler of the free world
Drives: 09 Yaris 2D HB
Manual Trans Fluid
Questions are for manual transmission fluid - NOT Auto.
1- Is OEM fluid synthetic or dino?
2- How does OEM fluid compare to redline MT-90 viscosity-wise? Is one thicker than the other, or about the same?
CueBall is offline   Reply With Quote
Old 06-10-2017, 01:48 PM   #2
Steve35
Steve35's Avatar
Drives: 2008 HB
I've always used Redline in my trans, the shifting is much easier.
https://www.redlineoil.com/product.aspx?pid=46
Steve
Steve35 is offline   Reply With Quote
Old 06-10-2017, 03:07 PM   #3
I've used a bunch of various fluid in my trans including MT-90. My current favorite that I'll be stocking with it Amsoil MTG, it's a true GL-4 75-90 which is recommend from factory.
If you aren't hard/fast shifting or driving in extreme cold temps than stock with oem. If not then go Amsoil imo.
Many on here had issues with mt-90 due to it being a GL-4 and 5 rated fluid. I personally didnt have any grinding issues but the Amsoil seems smoother and better in cold and last longer than the MT-90 which seemed to wear out after 10k km or so
I'm not sure what the oem fluid is
Old 06-11-2017, 12:40 AM   #4
SirDigby
Drives: 2007 yaris 3 door
1. OEM just states: gl-4 or gl-5 75w-90
most (pretty much 99%) dealerships use bulk oil barrels from a local oil company.
2.(generally speaking) it would very depending on the area/refinery dealership to dealership.
Old 06-11-2017, 07:02 AM   #5
dogsridewith
Drives: 2007 2-door hatchback
It looks like something is written on a white sticker on a 2007 drain plug. Anyone know what it says?
Old 06-11-2017, 03:31 PM   #6
zoidberg444
zoidberg444's Avatar
I used a cheap semi synthetic 75w90 GL4 oil when i did my clutch. Its only done 2000 miles so far so i can't pass judgment but i haven't noticed any real change apart from a slightly louder high pitched wine from the gearbox at 50mph.
I'm not sure there is a need for all singing all dancing fully synthetic gear oil unless you live in the northern US/Canada or maybe parts of central Europe or Scandinavia.
UK to Nordkapp in a Yaris
Old 06-12-2017, 06:07 PM   #7
CueBall
Thanks all.. Im not looking for suggestions on which fluid to use. I already know I'm using either OEM or MT-90.. I still have factory fill, and I don't want to put thinner oil in. If OEM is thinner, I'll switch to the MT-90. IF MT-90 is thinner I'll stick with OEM. Anybody got a fresh bottle of both to do a shake test?
Old 06-13-2017, 02:49 PM   #8
stykerdk
Yaris Hybrid Limited 2015
Castrol oil selector says singlegrade 75W GL4 oil, it also what my user manual says.
http://applications.castrol.com/oils...t-i-(2005-2009)
I cant link directly to yaris oils but select europe and UK.
I have put a pic in another thread in here from the manual with oil recommendations from my user manual.
The issue has also been discussed on the danish toyota forum, and the conclusion is that multigrade oil gives poor shifting and noise.
C-HR 1,8 Hybrid premium 2020
Dropping the tans in a 2zr swapped Vios tmontague Performance Modifications 2 04-29-2017 07:29 PM
Manual trans fluid change 2010 Yaris 3dr LB DANIELTNIEVES DIY / Maintenance / Service 2 08-21-2015 09:52 PM
Manual Trans fluid change problem dfhnpdx DIY / Maintenance / Service 3 08-12-2012 11:23 PM
manual trans fluid d2dailly DIY / Maintenance / Service 65 02-14-2009 07:38 AM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
