Old 06-21-2017, 02:07 PM   #1
MatthewMenze
Drives: 2012 Toyota Yaris Hatchback
Fog Lights?
Has anyone been able to retrofit fog lights from the previous generation (or universals) it looks like the bumper on my 2012 3dr LB has a spot where they would go.
Thanks,
Matt
MatthewMenze is offline   Reply With Quote
Old 06-21-2017, 02:12 PM   #2
m.flores.0928
m.flores.0928's Avatar
Drives: 2014 Yaris
Thanks,
Matt
The only difference is the trim piece. You can find trim pieces for the 3rd gen bumper (LE or SE trim specific) with openings for fog lights. The trim piece is just that, a trim piece. The mount for the fog light itself is on the backside of the bumper, and that trim piece is used only as a decorative cover.
That said, most (if not all) toyota fog light housings are the same amongst all models. Pick up some toyota specific fog light housings and a basic harness set up along with the proper trim pieces and you're good to go.
I found my kit on eBay for like $35, I have a 2014 model with the same bumper set up as yours.
m.flores.0928 is offline   Reply With Quote
Old 06-21-2017, 02:22 PM   #3
All Toyota but the Sienna foglights actually perform well. You'll probably hate the performance and try to upgrade the bulbs. My suggestion would be to pick up a Morimoto XB LED plug-n-play foglight for the Yaris (unless you wanted warmer colors).
https://www.theretrofitsource.com/hi...to-xb-led.html
Old 06-21-2017, 02:23 PM   #4
m.flores.0928
Drives: 2014 Yaris
Yes, get these! I've been saving for these.
Old 06-21-2017, 10:54 PM   #5
MatthewMenze
Awesome, thank you! Is there a good place to source the fog light trim pieces?
Old 06-21-2017, 10:59 PM   #6
m.flores.0928
Drives: 2014 Yaris
I bet eBay has some. A dealer isn't too expensive either
Old 06-22-2017, 12:06 PM   #7
hotracer_05
Hmm, I see...
hotracer_05's Avatar
Drives: 2012 Toyota Tundra and Yaris
http://www.ebay.com/itm/New-Fog-Ligh...1ZNqhE&vxp=mtr
"Everything happens for a reason. Sometimes that reason is you're and idiot"
hotracer_05 is offline   Reply With Quote
Old 06-22-2017, 01:03 PM   #8
m.flores.0928
Drives: 2014 Yaris
Originally Posted by hotracer_05 View Post
There ya go.
Mine have chrome rings, but these will do for OP.
Old 06-22-2017, 06:23 PM   #9
NJP440
2010EGGHATCH
NJP440's Avatar
Drives: White 2010 Yaris Hatch
From my experience the fog lights from eBay suck! The trim pieces seem just as good as oem but if still purchase OEM. You can find used OEM on eBay and many insurance sites. I have to agree with kaotic on this one tho, the morimoto is going to put perform even OEM.
Sidenote I used to run aftermarket fogs in my 2010 and they got moisture, cracked, and baked the bowls with regular halogen lights so that's my experience.
Sent from my LG-H918 using Tapatalk
IG: 2010EGGHATCH
NJP440 is offline   Reply With Quote
Old 06-22-2017, 06:26 PM   #10
m.flores.0928
Drives: 2014 Yaris
I want those Morimoto ones. For now though I have LEDs in my reflector housings. They run cooler than the halogens so they don't melt and look better. I need new LEDs though mine are flickering, but I'll just get the whole Morimoto kit before I get new bulbs.
Old 06-22-2017, 10:10 PM   #11
MatthewMenze
I know these are not the morimotos that everyone has suggested, but these are on micro images ebay page. Would these work okay? Or are they similar to the cheap ones you folks mention?
http://www.ebay.com/itm/172398523528
Old 06-22-2017, 10:12 PM   #12
NJP440
2010EGGHATCH
NJP440's Avatar
Personally I find all spyder products to be junk. Those are what I had
IG: 2010EGGHATCH
Old 07-01-2017, 09:48 PM   #13
ccyaris
Drives: 2012 Yaris L 3 Door 5 S
m.flores.0928 I used genuine Toyota housing, not very expensive plus OEM OSRAM LED FOGS FOGS from Amazon.uk shipped to US. Osram LEDFOG201 $83.71 and LEDFOG201 TY MOUNT $27.51.
ccyaris is offline   Reply With Quote
Old 07-08-2017, 07:07 PM   #14
naga viper
Drives: 2012 5 door & 2008 3 door
I have the morimoto led lights in my 2012 and the are the cats meow!
naga viper is offline   Reply With Quote
Old 07-09-2017, 06:53 AM   #15
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
I have Hikari LED bulbs in mine, both head and fog.
2 yr warranty and 9600 lumens.
It's like natural daylight driving.
They have a little fan on back of bulb, so fitment in fog is fine, but headlamp, the covers are snug.
If I am to buy again, I would only buy the LED's for the fogs, or go with PIAA yellows for fog and the silverstar ultra or whatever the best halogens are.
That said, I am happy with purchase of Hikaris, only disappointment is high beam throw.
Work great on my wife's Camry, high beams are the ultras, fogs are yellow PIAA's and low beams are the Hikari LEDS.
I consider the Camry bulb selections the perfect set up.
I got all lights off Amazon.
DIY yaris III fog lights installation karloslatynos Third Gen Yaris General Discussion 53 11-12-2017 03:03 PM
Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal V70R_Blackbrick Cosmetic Modifications (Exterior/Interior) 26 11-27-2013 10:14 PM
my Projector Fog lights project ezhacker1 Cosmetic Modifications (Exterior/Interior) 3 01-10-2010 05:21 PM
Fog Lights Poll Reeves360 Cosmetic Modifications (Exterior/Interior) 14 12-27-2009 02:00 AM
Sedan Fog Lights, few questions!(where to get) ( make into HID Fog Lights!!!) Lafiro Cosmetic Modifications (Exterior/Interior) 2 06-12-2009 03:56 PM
