Old 07-14-2017, 11:10 PM   #1
slolude
Fog light problem
Hi, I wired in a set of fog lights. I bought the headlight stalk with the fog. And the blue relay. I got everything wired in. And the fog lights didn't come on. I tried turning the high beams on and off just to make sure I wasn't on the wrong one. I took the blue relay out and jumped it and the fog lights did turn on. So the wiring in the engine bay is correct. The only thought I am having right now is the running light relay is disconnected. I can't find it or I would have tried it. If anyone has fog lights could you help me out and disconnect the running light relay module. And see if your fog lights turn on thanks
slolude is offline   Reply With Quote
Fog Light wiring Rammy DIY / Maintenance / Service 0 11-08-2012 08:34 PM
HID flickering problem - DRL fog - Problem solved. IllusionX Cosmetic Modifications (Exterior/Interior) 9 10-01-2009 06:37 PM
Sorry! Another fog light question. Jrilla DIY / Maintenance / Service 4 08-23-2009 02:25 PM
My Yaris Fog Light ezlove0710 DIY / Maintenance / Service 7 08-07-2009 06:15 PM
Fog Light Misalignment and Moisture DjT General Yaris / Vitz Discussion 3 04-27-2009 03:24 PM
