Old 07-17-2017, 07:22 AM   #1
Yaris in France
Drives: 2013 Hatchback
Odd occasional slight clunk
Greetings,
I have a 2013 Yaris (hatchback) ... mileage = 18,000 miles. I've recently noticed a slight clunk (but only occasionally) under some of the following conditions:
1. Downhill (but not necessarily on uphill corners) on tight turns regardless of whether the brakes are engaged or not.
2. Turning into a parking space.
Since I will need to take it to a mechanic here and will be dealing with this in a language I don't speak well, I'd like to have a hint ahead of time as to what might be the problem.
I thought perhaps the car needed to be lubed, but I guess cars this new don't need to be lubed (?)
I should add that I live in a very windy area near the sea with heavy salt air seasonally.
thanks ...
Yaris in France is offline   Reply With Quote
Odd throttle issue Suzaku DIY / Maintenance / Service 19 02-03-2022 07:49 PM
Motormount causing front end clunk? cabinfevrr DIY / Maintenance / Service 14 07-06-2015 06:31 PM
'02 Echo Suspension clunk fix tmontague DIY / Maintenance / Service 5 06-29-2015 11:02 AM
Solved: Clunk in Rear Suspension (2008 Yaris 3-door) Redbat01 DIY / Maintenance / Service 2 02-10-2015 12:33 PM
steering wheel slight vibration high speed??? marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 10-01-2012 06:36 PM
