Old 07-17-2017, 11:56 AM   #1
sachin53
Drives: 2009 toyota yaris
All electricals shut down
Hello,
2009 Toyota Yaris Sedan
Was cranking but no start.
Battery good.
Checked the fuel pump electrical connection and was getting around 11.xx volts on 2/4 pins.
Checked the starter relay. Thought that could be the problem, so replaced that.
What happened yesterday was, I put the starter relay in place, turned the key to ON position. It showed all lights on the dash, I tried starting the car and everything just shut down on me.
Took the keys out and put it back in, turned to on and all dark. No lights on the dash. Nothing....
Help!
Sachin
sachin53 is offline   Reply With Quote
Old 07-18-2017, 09:51 AM   #2
sachin53
Hi Guys,
I just wanted to update that the electrical shutting down on me was a bad battery connection. Cleaned the corroded terminal with sand paper and now its back to the point where its cranking but no start.
I also noticed that belt was moving slower than usual.
Sachin
Old 07-18-2017, 01:23 PM   #3
sachin53
I got the battery checked and it showed a good battery with 854 CCA.
Sachin
Is microimageonline shut down? marcus General Yaris / Vitz Discussion 1 05-27-2015 11:05 AM
Need help guys headlight won't shut off!!!!! marcus DIY / Maintenance / Service 17 06-26-2014 12:59 PM
'system shut down' on Mk.3 Yaris. Geoff Peace DIY / Maintenance / Service 6 01-12-2014 01:40 PM
Does your trunk shut as easy as other cars? BennyLava DIY / Maintenance / Service 11 01-01-2012 10:41 AM
Keep your mouth shut. yaris-me Off-topic / Other Cars / Everything else Discussions 19 05-27-2009 12:18 PM
