Old 07-24-2017, 08:40 PM   #1
Pinchlite
Drives: 2007 yaris HB
Floaty feeling at higher speeds common?
2007 2 DR HB.
The car handles great,new dampers all round with 1.5 drop.205/50/R16.Michelin pilot a3+(not sure if thats correct tire name)
The car does not pull or feel bad,but it just kind of feels as the front end is getting airborne...of course its not but thats best way to describe.The steering also becomes very,or more sensitive.This is 140 kmh.I know,Iknow but I was going with the flow.This was the first real highway drive I have had with my yaris btw.
Someone mentioned low tire pressure?.I have 38 psi like kal tire put it at...
Pinchlite is offline   Reply With Quote
Old 07-24-2017, 10:18 PM   #2
SirDigby
Drives: 2007 yaris 3 door
uh...that's really high tire pressure. since your city is at 249 feet (76m) i'd put them sticky shits at 28psi-30psi (193kPa-207kPa)
do you have a print out of your alignment? sounds like a toe issue maybe. are the tires rotating the correct direction? sometimes tires mounted in the wrong direction will have this effect.
there is differently something wrong. did you install adjustable sway-bar end-links with your drop? what brand of strut/shock/springs?
i do that speed everyday, stock suspension with 80,000 miles (128,750km) on them. (upper strut brace, rear sway bar have no effect on straight line) feels comfortable all the way to 112mph. (180kmh)
Old 07-24-2017, 11:12 PM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
When I had my '07, I increased the tyre pressure (on my 205/50/16's) to 38PSI, the car bounced around like a basketball at low speeds and felt like it was floating at higher speeds. Drop your tyre pressure to about 30PSI and see if it makes a difference.
Old 07-25-2017, 05:35 AM   #4
Pinchlite
Whoa!...30 PSI?
I dont feel bouncing at any.The ride is pretty tight.Maybe you had worn dampers?
I will get shit mileage at 30 psi?
Old 07-25-2017, 06:29 AM   #5
dogsridewith
Drives: 2007 2-door hatchback
Yaris tire pressure stagger weight distribution slip angle Beetle
Driving unloaded? At least evaluate w/ the 38 front and 30 psi in rear.
Handling is a lot about what I recall are called slip angles--something like angle between aim of rim and path of tire contact patch? Has to be slip angle to generate cornering force. Slip angle is inversely dependent on tire pressure...at least until things get really broken loose. Old rear engine air cooled Beetles had weight bias as severe the other direction as our 3-door Yaris. Rear tire pressure at least 5 psi higher than front really helped control oversteer. Maybe your front end floating sensation at speed is some understeer?
Old 07-25-2017, 10:08 AM   #6
kimona
kimona's Avatar
Originally Posted by Pinchlite View Post
Whoa!...30 PSI?
The information I provided was when my '07 was new and I was experimenting with tyre tread patterns and tyre pressure.
Here's recommended tyre pressures for the Yaris: http://blog.toyota.co.uk/toyota-tyre...ze-guide#Yaris
Tyre Pressure:
14-inch wheels (175/70/14): The front tyres should be inflated to 36 psi. The rear tyres should be inflated to 35 psi.
15-inch wheels (175/65/15; 185/60/15): The front tyres should be inflated to a minimum of 33 psi and to a maximum of 36 psi. The rear tyres should be inflated to a minimum of 32 psi and to a maximum of 35 psi.
16-inch wheels (195/50/16; 205/50/16): The front tyres should be inflated to 32 psi for speeds below 99mph and 35 for speeds above. The rear tyres should be inflated to 29 psi for speeds below 99mph and 30 for speeds above.
Old 07-25-2017, 11:18 AM   #7
enviri
enviri's Avatar
Drives: 2010 Yaris
WOAH! i played around with pressure alot on my car and i ended up with 33 front 31 rear just last week because the car didn't feel right!! I didnt know i was so spot on lol. (sw connecticut highways go from 70-110mph cause everyone here drives high end german/italian no one gives a damn lol.)
Old 07-25-2017, 04:50 PM   #8
MadMax
MadMax's Avatar
Whoa!...30 PSI?
No, but you're tires will last longer and you'll get better traction out of them.
This car gets decent enough gas mileage, I don't understand this infatuation with squeezing an extra couple of miles out of a gallon. Most of the time it's at a sacrifice to handling or even safety.
There is a balance to be achieved when it comes to tire pressure, enough to maximize the mileage, traction and handling. If you increase one of those factors, you decrease others. Simple physics.
Old 07-25-2017, 05:30 PM   #9
Pinchlite
Tyre Pressure:
Alright then.I will give this a go when tires are cold in the morning.
32 and 29 psi.
Looks like the tire place just went with what was on the door jam.
Old 07-25-2017, 05:31 PM   #10
Pinchlite
Going to go 32 and 29 front/back.
Thanks for insight.
Old 07-25-2017, 05:31 PM   #11
44psi like any hypermiller. Haha
TBH, I run 35psi all around. Verify it at room temp, in shade.
Sent from my SM-G930W8 using Tapatalk
Old 07-25-2017, 05:34 PM   #12
Pinchlite
gong to try this 32 and 29 psi after reading comments from what I think are some really knowledgable fellas.
Makes sense to have less in the rear.
I do appreciate the reply though.
Old 07-25-2017, 05:34 PM   #13
Rigaud
Drives: 2009 Yaris
Did you instal a rear sway bar?
2009 Toyota Yaris (Little toy)
2002 Audi A4 Avant Quattro 3.0L (Big boy toy)
1998 Subaru Legacy GT 2.5 (winter & DD)
Rigaud is offline   Reply With Quote
Old 07-25-2017, 08:17 PM   #14
SirDigby
Whoa!...30 PSI?
you don't buy Michelin Pilot Sport 3 tires to get better fuel millage.
if your goal is fuel millage you buy those silly low rolling resistance tires.
if you buy performance tires, your goal should be maximum performance, otherwise save yourself $200(USD)
Old 07-26-2017, 06:38 AM   #15
Pinchlite
Not sayng its uncomfortable.The car stays true as in zero pull.No vibrations.
New Tires are on correct with new KYB shocks.
I ckecked pressure cold last night 32 all round.These are not super sticky tire and many use this exact tire and are pleased as am I.
Perhaps Iam just not used to the yaris at higher speed?
The car drives absolutely firm amd feels really responsive.Really,really impressed overall.Drives nicer then a new fit and civic si which are both 2016 and I have driven both.
The civic feels like a boat and the fit just feels cheapish,kind of like a chevette,pontiac acadian or escort I once owned.
Could a bad stabilizer bar(One that connects to front shock absorber) cause issues like I described.
I think that is rattling.
I have new cv drive shaft going in this weeekend due to torn boot so i will have mechanic give it a thorough go over.
Old 07-26-2017, 06:42 AM   #16
Pinchlite
Tyre Pressure:
Old 07-26-2017, 08:32 AM   #17
It's likely the fact that the yaris is such a light car than many others that you're used to. I found running wider tires, rims with a wider offset and more negative camber helped a lot for high speed stability.
I run 40/36 f/r for tire pressure. Mainly because I travel a lot of km's a year and I found anything less caused ore nature seat on the shoulders of the tire relative to the middle. Any pressure higher than that and the bride was too rigid
Old 07-26-2017, 09:38 AM   #18
Rigaud
Drives: 2009 Yaris
32f - 28r
205/45R16
1ZZ throttle body and intake, header, 2-1/4" freeflow ss exhaust, lowered and TRD sway bar.
@ 95-100kph I do 5.4 to 5.6L/100km Hard driving.......7.4L/100km
Fuel economy is all about how you drive.
My 2009 2dr hatch swayed....floated on the highway before the sway bar was installed. It holds straight like on rails since.
Just filled up the tank with 91 octane premium fuel darkmoon87 General Yaris / Vitz Discussion 105 10-02-2016 08:35 PM
How about higher speeds? BensVitz General Yaris / Vitz Discussion 25 05-10-2006 10:09 AM
