Old 09-02-2017, 03:49 AM   #1
rabbito
rabbito's Avatar
Cam, dyno and tune = problem
installed pair of 264 9.5 cams, same as JUN regular series(not bolt on)..
i thought 250cc was enough with these cams...my fuels was done before hitting high rpm or during the tune...fucken sucks(sorry for the language)...so we stopped the dyno for now until i upgrade them to larger injectors 330cc and above...sigh
yes injector cc do gets maxed out....
you can see the dots going up and down unevenly after 5500rpm...
they said im not using full potential of the cams at all due to low fuel injection so until next time........
- i remember stock 1nz injectors were 160cc? correct me if im wrong...
- i remember stock 1nz yaris produce 81 or 82whp on dyno...
- todays weather: almost 40c..104 degrees...hot af with heavy humidity here in thailand
- current outcome on dyno is 103whp thats only 140hp...
Sent from my SM-N920C using Tapatalk
Cosmetic: Toyota red emblem
Granite State Dyno & Tune Open House fnkngrv New England 0 03-18-2014 11:35 AM
N/A performance tune yaris2010RS Performance Modifications 3 12-13-2012 01:33 AM
Tiamat 10 July 12 Dyno Tune and Results - Stock motor top speed found fnkngrv Forced Induction Forum 4 10-06-2012 11:00 PM
Dyno results PETERPOOP Forced Induction Forum 28 12-09-2009 11:01 AM
dyno results are in!!!! turboyaris Performance Modifications 105 04-01-2007 06:03 PM
