Old 09-25-2017, 07:35 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Replaced Downstream O2 Sensor
I've had a check engine light on since I bought the car. According to Torque Pro OBD2, I had zero volts on the bank 1 sensor 2. So, I replaced the sensor today and was disappointed that it still read 0 volts while idling in my driveway, however the MIL did not return. But I went for a drive and now it works. Getting a good sweep from 0.1 to 0.9 volts and air fuel ratios, commanded and measured, are perfectly in sync. I found the answer on another Toyota model car/truck forum.
Anyone want to guess why it didn't appear to work at first?
DIY : changing the Oxygen / O2 sensor on Yaris hatch MANY PICS auxmike DIY / Maintenance / Service 50 12-10-2024 12:39 PM
Rear Speed Sensor Install Help? (ABS Sensor) towerofpower DIY / Maintenance / Service 2 04-07-2014 06:32 PM
Upper O2 sensor replaced but did not fix the problem Hard_Yaris DIY / Maintenance / Service 9 04-10-2013 10:22 AM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
