Old 10-03-2017, 12:08 PM   #1
bronsin
bronsin's Avatar
Maintence Items Not In The Owners Manual
Spray each wheel with lube where indicated in the photo maybe once a year to prevent it from seizing to the hub. Maybe more often in Canada!
Old 10-04-2017, 09:40 AM   #2
A permanent solution is to just apply anti seize or grease on the hub. My car is an 05 and I've never had a wheel stick to the hub, or brake rotor.
Old 10-04-2017, 12:17 PM   #3
bronsin
bronsin's Avatar
Good idea. Ive had them stick and kicking the tire while its on the supplied jack during a roadside emergency to get it off was scary! I ll use sntiseize if I ever have any of the wheels off. Im old and getting the wheels off is an adventure!
Old 10-04-2017, 01:06 PM   #4
Antiseize ftw!
Old 10-04-2017, 09:34 PM   #5
I don't seem to have issues with mine the past 2 years.
But anti seize does the trick if it sticks.
Sent from my SM-G930W8 using Tapatalk
Old 10-04-2017, 09:45 PM   #6
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Maybe a Canadian thing. I do that to mine too, just to keep the rust off. Actually, I spray the whole steel wheel (my winter ones) a few times a season and they still look new after many Canadian winters.
Old 10-05-2017, 04:07 AM   #7
bronsin
bronsin's Avatar
I should've done that. Mine are rusty after eight years and I live in New Jersey!
Old 10-05-2017, 12:23 PM   #8
nortonfb
Drives: 2007
Every year when I switch back to my winter tires, I wire brush and add never seize.
I hate stuck wheels. Michigan winters are not fun especially with salt.
nortonfb is offline   Reply With Quote
Remote Start DIY Wiring Guide 2006-2010 Yaris CTScott DIY / Maintenance / Service 272 01-22-2022 11:02 PM
2008 Toyota Yaris Owner's Manual dinky123! DIY / Maintenance / Service 3 03-25-2015 12:26 PM
Grimmspeed Manual Boost Controller For Sale fnkngrv Items for Sale by private party 1 05-05-2014 02:25 PM
Owners Manual Download?? JeffRapp DIY / Maintenance / Service 4 04-14-2011 03:37 AM
2009 Sedan Owners manual magnum23 DIY / Maintenance / Service 2 10-20-2010 11:50 PM
