Old 10-04-2017, 12:29 PM   #1
Tire/rim size question
Wondering if anyone is running 15x8 +25 rims on their Yaris?
If so any rub and what camber?
I'm trying to figure out if I can fit some konig dial in's on my car. Currently I have 15x7 +35 dial it's with a 1010km spacer in the rear with -2.5 f and -1.8r camber. I have plenty of room up front and a bit in the rear. Problem is the 8" only come in +25 offset.
I'm thinking this is a bit of a stretch so I may opt for the Hypergram instead as they are 7.5 wide and +35.
Just wondering what peoples experience is with those sizes.
Old 10-04-2017, 12:53 PM   #2
Steve35
Steve35's Avatar
Drives: 2008 HB
I tried these just for fun, they're off my Miata autocross car
https://www.tirerack.com/wheels/resu...9&autoModClar=
no rub at all on at stock height, but the front stuck out too far
Steve35 is offline   Reply With Quote
Old 10-04-2017, 02:36 PM   #3
What are the rim and tire dimensions?
Old 10-04-2017, 03:14 PM   #4
Steve35
Steve35's Avatar
Drives: 2008 HB
Wheels are what you asked for 15x8 25mm, tires are 205/50x15 BFG Rival 1.5's
Steve
Old 10-04-2017, 03:57 PM   #5
Do you have a side shot showing tire poke? Also I'm assuming you're running stock camber?
Old 10-04-2017, 05:05 PM   #6
Steve35
Steve35's Avatar
Drives: 2008 HB
Camber is stock, sorry no pics of the side shot and I've taken the tires off the wheels. You could see at least 1" of tread at the top of the tire.
Old 10-04-2017, 05:35 PM   #7
Thanks for the info!
I've been searching around the forum and found a few threads that discussed this ad nauseam and it seems like the best option for me in 15x7.5 +35 with a 195 wide sport comp 2 tire (they fit very large for their size)
Old 10-04-2017, 05:42 PM   #8
Steve35
Steve35's Avatar
Drives: 2008 HB
That is the wheel/tire combo I'm going with too. I use Tirerack.com all the time to verify fitments.
Steve
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 08:02 AM
Rims size question Kamikaze Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 02-01-2013 02:11 PM
Question about tire size with TRD drop. marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 01-29-2009 05:30 PM
Exhaust Pipe Size (Tamaņo del tubo de escape) carlosh Central and South America 11 08-02-2007 04:15 PM
