Old 10-23-2017, 06:36 PM   #1
jigglebutt
Drives: 2010 Sedan
Camshaft timing valve (OCV) o-ring size
Hey guys,
The camshaft timing oil control valve (OCV) assembly is leaking oil on my 2010 sedan (~67k miles) and new OCV's seem to be in the $100 range. Is there any reason why I shouldn't replace just the o-ring, instead of buying the entire assembly? I'm hoping to buy just a ~$1 o-ring at the autoparts store.
Additionally, does anyone know the specific size of this o-ring?
Thank you.
jigglebutt is offline   Reply With Quote
Old 10-23-2017, 07:25 PM   #2
Just an o ring replacement should be fine. I don't know the size however
Old 10-24-2017, 01:09 PM   #3
thetut
Drives: 2007 4dr sedan
See if your dealer has this part number: 90068-14030
thetut is offline   Reply With Quote
Valve timing help Sakis Deme General Yaris / Vitz Discussion 0 10-17-2017 09:47 AM
Bleeder valve fitting same size on brakes as clutch? ejaf DIY / Maintenance / Service 4 10-05-2016 12:39 PM
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-14-2014 12:17 AM
NEED ENGINE CHECK LIGHT CODE LIST Attitude Forced Induction Forum 12 04-11-2011 07:38 PM
