Old 01-01-2018, 07:05 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Valve Cover Bolt Size help. please.
I was inspecting behind my engine to see if I have any visible exhaust manifold leaks and noticed I'm missing one valve cover bolt. There is a small oil leak where the bolt is missing.
Does anyone know the specs on this bolt so that I can replace it? I am still planning removing the valve cover, but will need a bolt anyway.
EDIT: The bolt appears to be part Toyota 91511-C0622, but rather than order and wait for one. I'd like to try to match locally without having to remve another one.
Thanks in advance.
Old 01-02-2018, 05:53 PM   #2
06YarisRS
Nevermind. I took another one out and found a similar - though slightly longer bolt in our bolt bin. Length didn't matter as the holes in the head are drilled and threaded right through.
Whiteline Control Arm Bushing install and Review tmontague Performance Modifications 3 06-08-2019 02:42 AM
fuel tank heatshield bolt size? antone DIY / Maintenance / Service 1 04-05-2015 03:10 AM
FS: Polished Valve Cover Daddie Y Items for Sale by private party 5 10-11-2014 03:12 AM
Transmission Drian Bolt washer size CB900F2 DIY / Maintenance / Service 14 12-07-2008 07:03 AM
Exhaust Pipe Size (Tamaņo del tubo de escape) carlosh Central and South America 11 08-02-2007 04:15 PM
