Old 01-06-2018, 07:18 AM   #1
bronsin
bronsin's Avatar
Door froze shut will this help?
Door froze shut will this help? In the cold weather recently the weatherstripping on the drivers door of my wife’s car froze to the metal frame and you couldn’t open the door. We had to wait till it got warmer to open the door. With spraying the weatherstripping with WD-40 prevent this? Will the WD-40 harm the rubber?
Thanks!
Old 01-06-2018, 07:42 AM   #2
nortonfb
Drives: 2007
WD40, spray on, wipe off excess. No Won't harm rubber or paint.
It will smell and get on clothing, interior if not careful.
nortonfb is offline   Reply With Quote
Old 01-06-2018, 08:31 AM   #3
silicone spray is what you wanna use. It won't harm any rubber. You can also use it in the window tracks to help the windows up and down.
Old 01-06-2018, 10:00 AM   #4
bronsin
bronsin's Avatar
What is WD-40? I was thought it was silicone.
Old 01-06-2018, 10:03 AM   #5
dogsridewith
Drives: 2007 2-door hatchback
Frozen stuck door weatherstrip.
Any reason not to use DOT 5 Silicone brake fluid?
Waxed is likely better than nothing.
Old 01-06-2018, 10:11 AM   #6
Brake fluid will destroy your paint.
Old 01-06-2018, 04:42 PM   #7
SirDigby
Drives: 2007 yaris 3 door
it is fish oil.
olive oil works well too.
sil-glide is also a good product. (NAPA)
Is microimageonline shut down? marcus General Yaris / Vitz Discussion 1 05-27-2015 11:05 AM
Need help guys headlight won't shut off!!!!! marcus DIY / Maintenance / Service 17 06-26-2014 12:59 PM
'system shut down' on Mk.3 Yaris. Geoff Peace DIY / Maintenance / Service 6 01-12-2014 01:40 PM
Does your trunk shut as easy as other cars? BennyLava DIY / Maintenance / Service 11 01-01-2012 10:41 AM
Keep your mouth shut. yaris-me Off-topic / Other Cars / Everything else Discussions 19 05-27-2009 12:18 PM
