Old 05-26-2007, 04:57 AM   #1
Creeper
Creeper's Avatar
Drives: Silver 2DLB Yaris
Send a message via AIM to Creeper
Floorboard lighting
Im Installing some floorboard lights this weekend and was wanting to run then to a switch beside my aux jack infront of the e-brake. Now i am uncertain where to run the wires from there. I have a cupple friends that know this kind of stuff coming over to help. I just wanted to know if anyone had any ideas because I do not know ( thats why they are coming over, together they have installed stuff like this in about 18 cars).
Any advice that anyone could give would really help! I just dont want to look like a complete idiot when we get around to it.
p.s. I dont know shit about cars or working on them...
Creeper is offline   Reply With Quote
Old 05-26-2007, 08:09 AM   #2
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Definitely get help but have your buddy go to Autozone or wherever and get one of these add-a-fuse thingies for mini-fuses:
Here is what mine looks like with two added:
I chose to put them in their own slot rather than putting two fuses into an existing slot - your choice.
Old 05-26-2007, 09:24 AM   #3
Sway84
Sway84's Avatar
Drives: 07 Yaris HB
Send a message via MSN to Sway84
the fuse ad-a-slots allow the battery to work for the lighting?... cause i want to get some lights in the ride, but dont want to use the aux power in the dash
Rice on, Rice Off
Ron Cabading
Sway84 is offline   Reply With Quote
Old 05-26-2007, 09:28 AM   #4
Violin
Violin's Avatar
Lighting or whatever else you want. We have a bunch of emply slots - both switched and unswitched.
Old 05-26-2007, 09:29 AM   #5
Sway84
Sway84's Avatar
Drives: 07 Yaris HB
sweet...and how much do these things cost? cause i want to get a set of at least 4 tubes for the interior
Rice on, Rice Off
Ron Cabading
Old 05-27-2007, 08:27 AM   #6
Violin
Violin's Avatar
Cheap - about $5.
Here's a better photo:
One fuse supplies power to the original circuit, the other to the red wire. Like I said, I chose to use an empty slot and just use the fuse to the wire.
Old 05-27-2007, 08:34 PM   #7
Sway84
Sway84's Avatar
Drives: 07 Yaris HB
where can u buy these mini fuse thingys... aside from autozone?...
Rice on, Rice Off
Ron Cabading
Old 05-27-2007, 11:02 PM   #8
Creeper
Creeper's Avatar
thanks for the info, should have pics up soon
Old 05-28-2007, 12:56 AM   #9
eijikikimaru
Q(','Q)
eijikikimaru's Avatar
Drives: 3dr Meteroite
If you can, make a DIY for others interested in doing the same mod... Please
eijikikimaru is offline   Reply With Quote
Old 05-28-2007, 02:21 AM   #10
Creeper
Creeper's Avatar
ill try to ill have to go back and take pictures as soon as i get my cam fixed, very very simple can be done in about 15 -20 mintues te way i did
Old 05-28-2007, 09:09 AM   #11
Sway84
Sway84's Avatar
Drives: 07 Yaris HB
question...ive got a strobe bass recognizer dash neons and wanted to know and i bet its possible, if i could splice the wires and connect them to a whole next set of neons for them to intertwine strobing?
Rice on, Rice Off
Ron Cabading
Old 05-28-2007, 11:08 PM   #12
Creeper
Creeper's Avatar
Not sure, but make sure you check the local laws. I know in Georgia all blinking lights no matter what color other then blinkers are illegal, also a lot of colors esp. blue are illegal.
Old 05-29-2007, 12:33 AM   #13
Yaris Omega
Finsh the Fight
Yaris Omega's Avatar
Drives: soon to be Yaris LB
well that sucks that they dont let you put whatever color you want wit out being illegal
Yaris Omega is offline   Reply With Quote
Old 05-29-2007, 07:13 AM   #14
Violin
Violin's Avatar
You also don't want your wife/girlfriend/sister pulling over for some creep with a flashing blue or red light kit, do you?
Interior Lighting Typer73 Cosmetic Modifications (Exterior/Interior) 3 05-08-2007 05:34 AM
Guage cluster lighting Jem_hadar Cosmetic Modifications (Exterior/Interior) 3 01-26-2007 10:32 PM
Interior Lighting Q Yar Cosmetic Modifications (Exterior/Interior) 9 11-09-2006 06:55 PM
ambient map lighting? atebit Cosmetic Modifications (Exterior/Interior) 0 11-05-2006 01:15 AM
Blue Lighting option... fnkngrv Cosmetic Modifications (Exterior/Interior) 14 09-03-2006 12:24 AM
