Old 03-03-2018, 08:12 AM   #1
Bazilwasp1970
Drives: Toyota yarris 1.0 2008
PCV VALVE ON 1.0 TOYOTA YARIS 2008
Can anyone assist in locating the PCV VALVE for my Toyota yarris 1.0 2008 . A image of where it is would be appreciated.
Bazilwasp1970 is offline   Reply With Quote
Old 03-04-2018, 07:13 PM   #2
castles
Drives: 2008 Yaris
PCV valve:
https://www.youtube.com/watch?v=VikC_7NlIy8
castles is offline   Reply With Quote
Old 03-04-2018, 07:48 PM   #3
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Originally Posted by castles View Post
That's an NZ not a KR engine.
Old 03-04-2018, 07:57 PM   #4
NYC-SE
NYC-SE's Avatar
I can't cut from this doc. But if you follow this link there is a diagram on page 89 showing the location on a 1KR-FE:
http://webpages.charter.net/scott.mc...%20Control.pdf
Old 03-06-2018, 05:02 AM   #5
zoidberg444
zoidberg444's Avatar
Back of the engine behind where the oil cap is there is a hose that goes in. Take the hose off. It goes into the PCV valve. I take mine off and squirt some carb cleaner through it every time I change the oil.
UK to Nordkapp in a Yaris
Old 03-07-2018, 04:28 PM   #6
esse10
Drives: 2009 yaris 2 door
cleaning
I don't believe you need to clean it every oil change, once every 6 months should be sufficient IMO. It's just a block valve that works with positive pressure, if it raddles when you shake it than it's good to go.
Old 05-21-2018, 05:08 PM   #7
drusoider
Drives: Toyota mk1 1.4d-4d
Hello. Where did you bought the pcv valve. Any link please?
Sent from my MI MAX 2 using Tapatalk
drusoider is offline   Reply With Quote
Old 05-21-2018, 11:53 PM   #8
komichal
How often do you change oil? I do it every 8,000 km (approx. 6 months) and I think I am a freak. Your post suggests that you change oil even more often...?
2008 Toyota Yaris airbag light ON Temeku DIY / Maintenance / Service 0 10-22-2016 08:02 AM
For Saie: Tanabe springs 2008 up Scion XD 2007 up Toyota Yaris KSIbucky Items for Sale by private party 0 07-13-2011 02:11 AM
2008 Toyota Yaris official shop manual Reddog99 Items for Sale by private party 2 06-20-2010 05:34 PM
