Old 04-12-2018, 10:00 PM   #1
Drummy
Drummy's Avatar
Drives: 2008 Toyota Yaris Hatch
Whiteline Swaybar
Hey all!
It's been a while, but in that time I rummaged around in the forums gathering information on the swaybar and I finally caved.
It's an awesome purchase and I love the way it feels when I drive.
Just gonna go over a couple things I encountered during my install.
So the first problem I had was getting the OEM bolts out. Those shits were rusted on from years of the previous owners driving. I had to get creative in how I got them off, resulting in this little... Thing...
So little explanation, that is my breaker bar attached to the bolt, with a ratchet on the nut, being held in place by some bricks. No, the car is not being held up by the bricks, it is held up by jackstands. It worked surprisingly well, since the breaker bar could be used like a ratchet.
Once those were off, the bolts came out, and I could get the swaybar bolts in. Except they were too long and ended up needing to be forced in up against the back of my Brakes. That was taken care of with a little wiggling and some light hammering.
The next big challenge was the nylock nuts on the whiteline bolt. Kind of hard to do when you don't have an Allen wrench. So I improvised. I took a small u-bolt with nuts that were the exact size of the allen wrench needed, threaded a socket on the end of the u-bolt, and used a 1/2 inch drive ratchet to secure it. Once that was done, the hard part was over, and things started to line up nicely.
Now I am left with this beautiful piece of equipment that was a PITA. But I loved every second of the install. Every problem I found a solution to was icing on the cake.
So all-in-all, the install wasn't too hard, and could have been done a lot faster than the 5 hours I took, most of which was taking off rusted bolts with nothing but hand tools, if you had proper tools.
Drummy is offline   Reply With Quote
Old 04-12-2018, 10:24 PM   #2
Nice. Could of just heated the bolt though. I guess as long as it did not break.
Sent from my ONE A2005 using Tapatalk
Old 04-13-2018, 08:07 AM   #3
Drummy
Drummy's Avatar
No heat. Only thing I would have had was a propane torch
Old 04-13-2018, 10:05 AM   #4
Propane torch will do the trick, it just takes longer. Once your propane runs out grab a yellow bottle of MAP has (iirc) it burns hotter than propane and works a bit quicker
Whiteline Control Arm Bushing install and Review tmontague Performance Modifications 3 06-08-2019 02:42 AM
Whiteline rear swaybar mr_robot Items for Sale by private party 8 11-25-2017 09:32 PM
FS whiteline rear swaybar for 2008 yaris benzilla Items for Sale by private party 5 01-14-2017 11:30 AM
Whiteline Performance Swaybar tomsimmons82 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-25-2016 09:28 PM
MI springs and swaybar. Which swaybar? Flipper_1938 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 07-02-2011 12:42 AM
