Old 05-19-2018, 07:47 AM   #1
RicStyx
Drives: 2012 Toyota Yaris 1.3 -3rd Gen
Vortex Generator
I noticed a while ago the newer yaris has a small vortex generator on the inside of the wingmirror base to reduce wind rush. And then i thought about how much noise there was between the wing mirrors when driving at speed.
So I decided I'd make my own and see if they work. I 3D printed them and painted them. Used a good double sided tape to stick them down. Unbelievably they actually work. There is a very noticeable decrease in wind rush. Has anyone else done something similar and also noticed a difference. Granted these are a bit big for the car but they do the job.
Sent from my SM-N910F using Tapatalk
RicStyx is offline   Reply With Quote
Old 05-19-2018, 08:46 AM   #2
I'd have to say you are the first. At least the first to have talked about doing something. Not been too much mention of people 3D printing car parts either. Good for you.
Old 05-19-2018, 12:03 PM   #3
DarkShadowFox
but do they decrease the wind noise.
Old 05-19-2018, 05:27 PM   #4
Runethecursed
Drives: 2009 Yaris S
Cant hear the wind over my exhaust....
cant hear anything over my exhaust..
Runethecursed is offline   Reply With Quote
Old 05-19-2018, 05:42 PM   #5
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Then you need a better exhaust guy
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 05-19-2018, 11:24 PM   #6
Alain93
Drives: Yaris 12
Hi, could you put the file up?
Sent from my SM-T530NU using Tapatalk
Alain93 is offline   Reply With Quote
Old 05-20-2018, 01:25 AM   #7
Kalispel
Kalispel's Avatar
Drives: '15 Yaris SE 5MT
That's pretty cool.
Kalispel is offline   Reply With Quote
Old 05-20-2018, 06:17 AM   #8
mrpj
Drives: 2014 Icon+ 1.33l Multidrive
My Mk3 (U.K.), pre facelift, same as the o.p., has a plastic piece factory fitted to the driver's side only and much less obvious. Designed to do the same thing. I'll try to post a picture.
mrpj is offline   Reply With Quote
Old 05-20-2018, 06:54 AM   #9
mrpj
Driver's side.
Old 05-20-2018, 07:00 AM   #10
mrpj
Passenger side.
Old 05-20-2018, 07:08 AM   #11
RicStyx
My car has that too, but that is more to counter the difference in wing mirror shape if im not mistaken. Newer models have a small vortex generator on the passenger side to counter the wiper blade air being channelled there. I put 2 on each side, one right by the base and further up the trim. I had to place the ome further up as it was a flatter surface to mount it. But if you look from behind the car the two are directly in the range of the wing mirror, and help disturb the air so it can pass around the problem area.
Old 05-20-2018, 08:56 AM   #12
dogsridewith
Drives: 2007 2-door hatchback
Deer Whistle Toyota Yaris
On each side, I placed a deer whistle ahead of the mirror base...stuck to that black trim piece on the fender.
(There are four on the 91 Corolla--two taped into the empty fog-lite holes in the bumper cover, and one stuck at each end of the cowl trim piece ahead of the mirrors.)
Old 05-20-2018, 04:39 PM   #13
DarkShadowFox
sound like an exhaust leak.
Old 05-21-2018, 02:08 AM   #14
mrpj
"the difference in wing mirror shape "?
They are both the same shape in spite of being left and right handed.
Old 05-21-2018, 09:27 AM   #15
RicStyx
Sorry, difference in position, the passenger is slightly more towards the window than the driver to counter for the difference in distance.
Old 05-23-2018, 10:39 AM   #16
atomic_hoji
Drives: 2018 Yaris SE 5MT
for a clever solution. Nice work!
-- Adam
Old 05-23-2018, 03:08 PM   #17
scylla
Here is Toyota's explanation about adding vortex generators.
https://www.youtube.com/watch?v=4Bmhuq38EYI
scylla is offline   Reply With Quote
Old 05-23-2018, 06:20 PM   #18
justanotherdrunk
justanotherdrunk's Avatar
Drives: 2016 SE
interesting
i had no idea they help high speed stability
i thought it was only wind noise suppression
thanks for posting
vortex generators Idahotom Fuel Economy Forum 47 02-11-2017 01:01 AM
problem generator MickZEL DIY / Maintenance / Service 2 11-11-2016 05:43 AM
random stranger generator LOL 2006fronty Off-topic / Other Cars / Everything else Discussions 6 09-25-2009 09:31 PM
Mileage Maxx Vortex Generator xray scatter Fuel Economy Forum 8 12-21-2008 03:53 PM
