Old 06-03-2018, 04:00 PM   #1
komichal
Brake + clutch bleeding nipples
Hi folks,
I am getting closer to the brake bleeding using a power bleeder.
The brakes have been bled two years ago so I hope the nipples will not be too rusty and stiff and I will be able to loose them.
But... in case I cannot... and WD40 does not help... I would like to have some spare ones in case I need to get them out some nasty way (I know that with hexagonal wrench I should not strip them but who knows).
I have read a few articles and it seems that there may be actually several versions of those bleeding nipples differing in diameter, length etc... and that the only safe way to get a proper one is to screw one out, measure it and buy it then. Which is not a good advice in case I want to buy them beforehand.
Is there something like "common set of bleeders" I should get in case I do not know which ones fit? I know that front and rear nipples differ. And how about the clutch slave cylinder? Is the nipple there the same as for the front or rear wheels or is it a third size?
I am driving Yaris 2007 2SZ-FE 1.3 64kW hatchback 5-door.
Thanks for any comment on that... :)
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 10:42 AM
Aftermarket Clutch Q's tmontague Performance Modifications 5 03-05-2016 04:33 PM
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 08:05 AM
Question on brake bleeding... Yarflana DIY / Maintenance / Service 6 04-03-2013 01:55 PM
