Old 07-09-2018, 08:51 AM   #1
bronsin
bronsin's Avatar
Back up lights don’t work
i’m working on a 96 tersel Who’s the back up lights don’t work. The owner says the balls were changed a couple years ago and I haven’t checked them yet but I’m assuming they’re good. Where would the switch be that actuates the back up lights? i’m assuming it must be either on the transmission or the shift lever of the automatic transmission but any heads up would be good, especially if you know about Tercel’s! Thanks!
Old 07-09-2018, 11:24 AM   #2
Dodge Aries K
My Yaris is a "racecar"
Drives: 2007 Yaris hatchback
I would also check every single fuse on the car. Also, will the car start in other gears besides park or neutral?
-Karl the Uber/Lyft Driver
Dodge Aries K is offline   Reply With Quote
Old 07-09-2018, 12:36 PM   #3
bronsin
bronsin's Avatar
I’ll check and get back to you. I have the car up on ramps and checked for a switch on the transmission or couldn’t find movies. It was on ramps it’s down now
Old 07-09-2018, 12:48 PM   #4
bronsin
bronsin's Avatar
Nope it only starts in p and n. To exhausted from changing the coolant and clean the battery terminals right now to check the fuses. I’m not sure I can get down on that level to see the ones under the dash I have Parkinson’s
back up lights...amber? matthewai Cosmetic Modifications (Exterior/Interior) 23 04-05-2011 01:19 AM
Why would my tail lights work but not my brake lights? rickyml Middle East 11 10-06-2010 10:27 AM
