Old 07-17-2018, 09:03 PM   #1
Hexx29
Drives: Toyato Yaris
Canister Purge Valve for 07' Yaris CEL - P0441
Getting error P0441. Was told by Autozone I need to replace the Canister Purge Valve. While inspecting the CPV I noticed one of the hose ends were deteriorating. I tried wrapping the end with electrical tape but the error code didn't go away. I had this same error code last year and it went away after replacing the gas cap. But error is back up again. Any recommendations?
Should I try to replace the gas cap and put a new hose on? Last resort I guess I'll replace the CPV ($70) - it looks pretty simple to install.
Also, where can I find this hose? (pics)
Thanks
Hexx29 is offline   Reply With Quote
Old 07-18-2018, 04:55 AM   #2
Hexx29
Can I test the CPV using this method? Clipping a 9 Volt battery to the CPV?? There's a video of an 02' Camry testing. Does mine operate different since its an '07 Yaris vs an 02' Camry? Video: https://www.youtube.com/watch?v=9Gd7BbB0N3U
I might have wasted money buying the part but can always return it.. Need to first..
Thanks
**SAFETY RECALL!! 06-07 YARIS HB & SEDANS** slvryaris DIY / Maintenance / Service 83 09-30-2012 12:25 PM
2007 Yaris LB - Valve Adjustments Pavel Olavich DIY / Maintenance / Service 3 03-30-2007 05:34 PM
