Old 10-21-2018, 06:39 AM   #1
Brick
Drives: 2007 Base Sedan
Cheap sound system/head unit upgrade via older Scion
Installed a T1808 head unit today from an 08 Scion xB, and sound quality is much greater than the aftermarket head unit that I bought the car with or the 2001 Toyota echo head unit I was experimenting with. I don’t know how this 2007 sedan sounds like with the factory head unit. Nevertheless, If you’re looking for a direct swap upgrade that’s tasteful to your pre 2010 Yaris design, I highly recommend this head unit, assuming your rear speakers are still good to go. Also this head unit cost me $20;pulled from a parts car from a junkyard 👍🏽
File Type: jpeg 49DE0EF8-7A92-4325-A37A-DECA5DB9098B.jpeg (61.6 KB, 100 views)
File Type: jpeg 2FF5ABEB-D7BD-4FB1-84E0-17D1A1B3A2E2.jpeg (109.7 KB, 102 views)
Brick is offline   Reply With Quote
Old 10-21-2018, 06:46 AM   #2
Brick
Also, this head unit transforms your speakers without you having to get complicated with audio settings. The middle “SSP” button takes your speakers from “neutral” to “hear” then “feel,” and it really wakes up those stock speakers!
Old 10-22-2018, 02:13 PM   #3
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Sweet!
On Instagram
On Wheelwell
Old 10-26-2018, 11:24 AM   #4
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Great lead! And that deck looks dope in the dash.
Old 10-26-2018, 04:38 PM   #5
phaznet
phaznet's Avatar
Drives: '07 Yaris Sdn
Very Nice!
phaznet is offline   Reply With Quote
SCION XB BRAKE UPGRADE froger Performance Modifications 3 06-24-2016 10:48 PM
Looking for a new head unit...the last piece to my sound system upgrade. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 24 11-11-2010 09:28 PM
Cheap sound system upgrade. I like it. kac In Car Entertainment + Electronics (audio / video / alarm) 11 06-22-2010 09:48 PM
