Old 10-25-2018, 12:13 PM   #1
Pinchlite
Drives: 2007 yaris HB
Is this a half decent caliper?
My front driver side is sticking and heating up the wheel.I replaced the pins and lubed when I changed the pads and rotor this summer.
Instead of pissing around I figured just get a whole new unit.This one seems really chea$.
I Not sure if I already burned out the bearing(Those are new aswell)
https://www.napacanada.com/en/p/CPR2...earchIndex=App
Pinchlite is offline   Reply With Quote
Old 10-25-2018, 12:29 PM   #2
Wait, you want to replace the whole caliper because the pins were seized which you have addressed and fixed?
Old 10-25-2018, 12:31 PM   #3
Pinchlite
They were replaced this summer(PINS)aswell as rotors and pads.
drivers side is sticking the last 2 days.
Old 10-25-2018, 01:35 PM   #4
Well it's a remanufactured caliper so should be no different than what you've got. Me, I'd first just check and re-lube the sliding pins. If however the piston itself is seized, then maybe I'd invest in a caliper replacement.
Old 10-25-2018, 01:40 PM   #5
Pinchlite
I put in new pins and boots a few months back.I lubricated with proper grease aswell.
I will take a look,but will most likely replace the whole unit.I dont want to be pissing about mid winter with stuck brakes.I see its a reconditioned unit.Perhaps I should find a brand new one,and possibly do both side while at it.
Old 10-25-2018, 02:34 PM   #6
I agree w/ Wee. Find out why sliders are sticking, unless it is a seized piston but that's unlikely.
What grease did you use? I have never found any brake grease to be as good as purple ceramic permatex. It's not cheap but much cheaper then a new caliper
Old 10-25-2018, 03:08 PM   #7
Hell, taking it in for a brake service is cheaper than buying new calipers!!!
Old 10-25-2018, 03:33 PM   #8
Pinchlite
I got the new napa caliper and it wont retract either.Going to have to get it towed to a shop.
Old 10-25-2018, 04:13 PM   #9
Pinchlite
Well I replaced the caliper.After a further look it may be a seized bearing.If i get someone to push the brake I can see the inner brake pad squeeze in and slightly retract.The wheel does not spin freely after i put wheel back on.I may just get entire hub unit with bearing and do it myself.Looks like I will be garaging the car a bit early this year either way.If it is the bearing it lasted 1 year.Its a national bearing if that means anything?
Old 10-25-2018, 04:49 PM   #10
Did you try rotating the hub when you had everything apart?
Old 10-25-2018, 04:55 PM   #11
Pinchlite
NO.I was planning to remove the caliper tomorrow and do that.I will take the other side off aswell to comapre.I dont know what resistance or drag is normal.
I have never had a wheel bearing give zero symptoms before failure.There is no play and zero noise.
From what I can see though the outer pad seems tight against rotor,and the inner pad that moves in kinda lopsided.To explain better the pad retracts but mostly on the top part of pad?
If it happens to be a bearing I will replace the hub and bearing as a unit.The price is not much more for entire unit and i wont need a mechanic to press bearing in.
Old 10-25-2018, 07:01 PM   #12
I didn't know that there was a full assembly for the front hub bearing?
Sounds like your sliders are seized to me
Old 10-25-2018, 07:05 PM   #13
Pinchlite
I installed new caliper.I can see the caliper retract when someone pushes brake.Looks to be a bad wheel bearing most likely.thing is the bearing has no play and is completly silent.Not all that unheard of for a bad bearing,but not common.
front caliper pin tunring wont' snug nambi_ DIY / Maintenance / Service 2 09-07-2018 07:34 PM
Passenger side caliper loose... baseballfan416 DIY / Maintenance / Service 5 08-17-2016 10:35 PM
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 08:05 AM
My Yaris with a lil' Half 'N' Half The Architect Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 05-18-2009 01:36 PM
Yaris half mask? kimona Cosmetic Modifications (Exterior/Interior) 1 06-14-2007 07:10 PM
