Old 11-12-2018, 09:32 PM   #1
romram
Drives: yaris hatchback
2010 2 dr yaris rear wheel bearing replacement
my car about 85,000 miles. got some sound at the back...seems to be the passenger side rear wheel bearing.
just want to have idea how much a OEM Toyota wheel bearing and corresponding average labor cost?
just to have idea before I have it repair/service
romram is offline   Reply With Quote
Old 11-12-2018, 09:51 PM   #2
I'm pretty sure the oem bearing is around $300-400 since it is the whole hub assembly as it does not come with just the bearing like the fronts do. I'm not sure how much book time the job would be but I'd say around 2-4 hours it probably would state
Old 11-12-2018, 09:57 PM   #3
romram
thank you.
just looking at video at youtube, just wonder how can they fix the rear wheel bearing so quick . doing it almost less than an hour
so I might decide to bring my car to toyota dealer, I know it will be quite expensive, but hopefully they will be more trustworthy than other repair shop...I hope.
Old 11-14-2018, 10:00 PM   #4
SirDigby
Drives: 2007 yaris 3 door
the hub is held in with 4 bolts. it is one of the easiest wheel bearings ever, in the entire world of history to replace, as far as wheel bearings go, in my experience.
Old 11-15-2018, 05:36 AM   #5
^until its gets seized due to salt. Then it can become a big job and take an extra couple hours. Air hammers make a big difference for that.
Any independant shop that is trustworthy will be able to do it no problem, I don't see a reason to need to take it to the dealership to have it done
Old 12-30-2020, 09:03 PM   #6
Abrahamlow
Drives: Toyota Rush
An interesting discussion about changing bearings, but the question is, is the bearing suppliers at each dealer different from one another?
Abrahamlow is offline   Reply With Quote
Rear wheel bearing LeetViet DIY / Maintenance / Service 1 08-29-2012 07:41 PM
Noise from rear of Yaris APS67 DIY / Maintenance / Service 5 09-25-2011 06:51 AM
