Old 12-30-2018, 12:12 PM   #1
bronsin
bronsin's Avatar
Replacing power steering hoses for an ECHO
I realize this is in for a Yaris but if you know the answer to this question please help!
My 2002 echo with 83,000 miles has corroded power steering hoses. There a middle sections and there are rubber sections. The metal ones are pretty corroded. I painted them with Rust converter and for now all is well.
Should the power steering Hoses fail, What is involved in replacing them? The hoses themselves are like $200, and they look pretty buried in the front end. What has to be removed to get at them to change them?
I have Parkinson’s in years past I would do this work myself. But that is beyond me now. Possibly I could just drain the of fluid out of the power steering, and drive manually but with Parkinson’s I don’t know if I’m capable of that.
Thanks!
Old 12-30-2018, 01:29 PM   #2
The hoses are not too had to access once the underbelly pan is removed. Find an aftermarket set for cheaper and swap them in if needed. The potential issue will be if any bolts are corroded.
I swapped my leaking hard trans lines for all soft hoses as the bolts were all completely seized for the original hard lines. However, a power steerig system sees much higher pressures and they run longer so completely removing hard lines isnt really an option
2018 Yaris SE 5MT - T-Sport w/Valvematic! atomic_hoji Performance Modifications 130 02-23-2019 11:56 AM
2005 echo rs steering wheel compatible with 2007 yaris??? Xlt00 Cosmetic Modifications (Exterior/Interior) 2 01-11-2018 04:53 PM
'02 Echo cooling fan potential problem tmontague DIY / Maintenance / Service 2 04-07-2015 10:06 AM
No power to engine fan ihateyaris DIY / Maintenance / Service 2 03-26-2015 06:33 PM
Power upgrades for 04 Echo Hatch RS white_rice DIY / Maintenance / Service 7 09-15-2011 10:07 AM
