Old 01-14-2019, 08:01 AM   #1
BennyLava
Drives: 1987 Silverado
Starter grinds sometimes?
2009 Sedan. I'm having some trouble with my starter. It seems to want to grind, for seemingly no reason. When I start the car when the engine is cold, the starter will grind. Doesn't matter how long you hold the key down. Also doesn't matter if I use the remote start I had installed. It will grind. But when the engine is warmed up, it never grinds.
The car has 210k on it, and its the original starter. Do old, worn starters grind? In my experience they just get weak and won't turn the engine over fast enough to start it, or they just quit working altogether. Never heard of one that would grind when the engine is cold.
BennyLava is offline   Reply With Quote
Old 01-14-2019, 08:39 AM   #2
Leegamer
Leegamer's Avatar
I've heard that could be the bendinx(I think that's right) gear inside the starter wearing out. Not sure if you can easily lube that, I've never had the starter out of my yaris but it would be relatively easy to get out and examine.
I'm a hermit named Lee
Old 01-14-2019, 03:51 PM   #3
GrayYaris
Drives: Gray
If you determine it's the starter I have a new Denso starter in the box. I ordered it when I had to replace my starter (fairly easy job, btw), but decided to go with a reman unit that was local. Never bothered returning it. I would have to take a look at what it's worth, but obviously I would sell it cheaper than buying it from a parts store.
That said, a reman unit would probably be even cheaper. The reman starter I have in my car has lasted over 100k.
GrayYaris is offline   Reply With Quote
Old 01-14-2019, 04:39 PM   #4
I'd be interested in that starter depending on the price and if there is proof that it is a new unit.
Old 01-14-2019, 04:52 PM   #5
GrayYaris
Drives: Gray
I'm not sure if I can prove it, aside from taking a picture. I believe it was purchased online, so I should be able to find a receipt. The unit is not at my apartment. I should be able to find time to pick it up within the week.
Thanks,
Chris
Old 01-15-2019, 03:55 PM   #6
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Mine did that. Changed the starter and have been good since. I documented it via YouTube video and people commented on how it was happening to them, too.
On Instagram
On Wheelwell
Old 01-16-2019, 08:52 AM   #7
BennyLava
Got a link? Saw several but I was wondering which one was your video.
Old 01-17-2019, 11:53 AM   #8
ern-diz
ern-diz's Avatar
Sure thing, my video is here. I used an image of my car for the thumbnail.
Best to watch on a computer as I put a pop-up at the moment the sound happens, which makes it easier to hear. Happens for just a split second as the car starts up. If it's the same sound you're hearing, you'll be able to identify it right away. And if it is the same sound you're hearing, you need a new starter lol.
On Instagram
On Wheelwell
Old 01-17-2019, 11:16 PM   #9
bairjo
Nothing wrong with grinding...
https://youtu.be/QiMQ7wMTGpU
Old 01-18-2019, 10:33 PM   #10
ern-diz
ern-diz's Avatar
On Instagram
On Wheelwell
Starter sticking or ??? CueBall DIY / Maintenance / Service 4 09-07-2014 01:52 AM
Remote starter recommendation and questions GrayYaris DIY / Maintenance / Service 3 05-30-2014 01:06 PM
Starter Kill david.gartee1 DIY / Maintenance / Service 7 03-01-2014 07:14 AM
starter kill & horn help spechuy DIY / Maintenance / Service 0 10-20-2008 01:30 PM
Starter dragging YarisTom73 DIY / Maintenance / Service 5 08-27-2007 12:11 PM
