Old 02-06-2019, 11:57 AM   #1
mrgodai
Drives: Yaris Seden 2008
Yaris 2008 ALL tail/brake lights not working, replaced fuse and bulb already
USA Yaris 2008 Sedan.
So it starts off with passenger tail/break light not working at all.
I replaced the bulbs in both of them and still off. I put it off for a month. Now I went to check, ALL the brake/tail light are not working! even the high one by the window. I checked and replaced TAIL and PANEL1 fuses and still no go.
From what I read it's probably a wiring problem.
How do I use a multi-meter to check? and is there a guide for where the wires are and what panels I need to take off to check them?
Thanks in advance.
mrgodai is offline   Reply With Quote
Old 02-06-2019, 07:24 PM   #2
Set your multi meter to DC volts then find your wire loom that goes to the lights that are not working. Simplest way is to start at the lights and work back. You will eventually fine that they all merge into one loom. There should be connectors along the way, disconnect them and ground your negative lead to the body if the car that you know is s good ground. Then take your red lead and test the pins in the connector and you should fine one is 12v when its given its signal (ie: brakes applied or 4 ways put on).
When you get to the first point where there is no power, look at the wiring or the connectors and you will likely find the issue. This is a simple way if you dont have wiring diagrams, but it is not as accurate
Old 02-21-2019, 08:23 PM   #3
SirDigby
Drives: 2007 yaris 3 door
i'm guessing it's the brake switch. or wiring to the brake switch. they are thin wires.
Old 02-22-2019, 07:25 AM   #4
dogsridewith
Drives: 2007 2-door hatchback
Do any of the lights on the rear end of the car work?
Old 02-22-2019, 10:28 AM   #5
bob225
Brake lights are a very simple circuit do your sidelights, 4 ways and directionals work ?
If so i would throw a brake light switch at it
bob225 is offline   Reply With Quote
Old 02-22-2019, 04:54 PM   #6
dogsridewith
OP said tail lights also not working.
2015 Yaris Tail Lights Not Working TBowman Third Gen Yaris General Discussion 1 11-20-2016 08:44 AM
2012 yaris hatch rear interior light not working ironarmscott DIY / Maintenance / Service 0 09-19-2016 08:48 AM
Fog lights, or parking lights stopped working sylvermagyk DIY / Maintenance / Service 4 03-24-2011 05:13 PM
