Old 02-19-2019, 02:12 PM   #1
bulls2030
Drives: 2007 Toyota Yaris
07 Yaris Auto. ABS & Brake light staying on.
Hello everyone!
First post here.
I have a 2007 Toyota Yaris Automatic.
My ABS and Brake Lights are constantly staying on. They turn off for a little bit but they constantly staying on for the most part.
I took it to a local shop and they are saying to replace both rear wheel bearings. Just wondering if anyone else has any experience with this?
I bought my yaris in August with 110k miles and now its at 120k.
bulls2030 is offline   Reply With Quote
Old 02-19-2019, 02:24 PM   #2
Lots of mammoth historical threads on this issue. Known problem with corrosion occuring in the rear abs connectors. There are tips on attempting to clean them yourself.
Sent from my EML-L09 using Tapatalk
Old 02-19-2019, 02:27 PM   #3
bulls2030
Can you point me to some? would appreciate it
Old 02-19-2019, 02:32 PM   #4
Put the following in the search box
ABS and "!" lights are ON again!
Old 02-19-2019, 04:53 PM   #5
bulls2030
What brand Wheel Bearings are the most reliable and cost effective? Moog?
Old 02-21-2019, 09:57 AM   #6
bulls2030
So I searched the forum. Seems like people are saying to replace the wheel bearing hub (which has the abs sensor attached to it). or theres another sensor that attaches to the wheel bearing hub? Can someone clarify which parts I should look at and replace?
Old 02-21-2019, 10:15 AM   #7
The threads describe procedures for disconnecting, cleaning, packing with dielectric grease and reconnecting the rear hub sensor connectors. This often solves the issue.
Old 02-21-2019, 10:29 AM   #8
bulls2030
So there's a sensor plug on the wheel hub bearing. And there is a wire harness that attaches to the wheel hub bearing. What is the wire harness called if i need to replace the wire harness as well?
I am going to show it to a different mechanic today or tomorrow so just want to get some knowledge about the issue.
Old 02-21-2019, 12:30 PM   #9
You will see a connector behind the drum, along with the hose line. You can't miss it. And you mechanic is supposed to be able to get the cable. It's available at AutoZone as well..
Sent from my CLT-L04 using Tapatalk
Old 02-21-2019, 06:50 PM   #10
zoidberg444
zoidberg444's Avatar
I had this exact problem on my car last winter. I just gave the connectors a clean when i did my spring service and it has been fine.
UK to Nordkapp in a Yaris
Yaris 2007 ABS & Brake light issue after wheel bearing change DevilzMafia DIY / Maintenance / Service 4 01-17-2013 09:24 PM
Toyota Yaris -06 VCC and ABS light went on? goedafred DIY / Maintenance / Service 4 03-01-2011 12:22 AM
