Old 03-31-2019, 05:01 PM   #1
yaris9876
Drives: yaris hatch 07 640K original m
bulb replace
will these work in a 2007 Yaris Hatch??any good?
https://www.ebay.com/itm/H4-9003-CSP...CMake%3AToyota
how do you put them in??
yaris9876 is offline   Reply With Quote
Old 03-31-2019, 05:36 PM   #2
Same as installing in a hatch...
If you don't know how to change a bulb, better let a professional do the job though.
https://youtu.be/afgk-_TowYY
Sent from my CLT-L04 using Tapatalk
Old 03-31-2019, 06:38 PM   #3
2bz
Drives: 2008 Yaris 3DR Hatch MT
Wow, the bulbs in the video make it look like daytime!
2bz is offline   Reply With Quote
Old 03-31-2019, 07:52 PM   #4
yaris9876
I have changed bulbs 10 times in my Yaris. PITA. But these look like you dont put that metal spring
in to hold them .Thats why I asked. Do I need to put spring clip in with these?
Old 03-31-2019, 07:53 PM   #5
Yes you do. Watch the video. You'll see how it workd
Old 04-01-2019, 08:25 AM   #6
nortonfb
Drives: 2007
It always looks good in videos.
Buyer Beware!
nortonfb is offline   Reply With Quote
Old 04-02-2019, 12:59 PM   #7
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
Are you sure that these lamps will shine brightly?
I like very much travel
MickZEL is offline   Reply With Quote
Old 04-02-2019, 01:10 PM   #8
myfirstyota
3 Yaris and counting..
Check out prolightz.com
Canadian seller. Plx3 LED h4 (9003?) headlights.
Not cheap but good quality, good cutoff. Better than eBay anything
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Brake Light Bulb Replace Tinkerman General Yaris / Vitz Discussion 5 03-08-2019 06:29 AM
Replacing headlight bulbs nsmitchell DIY / Maintenance / Service 47 02-14-2016 09:07 PM
Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal hasher22 DIY / Maintenance / Service 88 03-06-2014 06:40 AM
Headlight bulb change....more to it than meets the eye... Yarflana DIY / Maintenance / Service 0 03-24-2013 08:56 PM
How do you replace the factory fog light bulb DjT DIY / Maintenance / Service 6 10-25-2008 07:24 AM
