Old 04-23-2019, 10:04 PM   #1
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
Post C150 VS C50 transmission differences
While doing a build for a YW member, we learned a lot about how the older and newer transmissions differ. You can read the whole article HERE:
http://www.armstrongfamilyblog.com/a...0-transmission
Old 04-24-2019, 03:59 AM   #2
saikouguy
Drives: Toyota Echo
Great stuff, you did all the hard work for me/us I was planning on looking/comparing the differences too, Australia is littered with these C15(x) gearboxes.
Now I gotta find a C56 and do the same 6 speed as you did.
saikouguy is offline   Reply With Quote
Old 04-24-2019, 09:37 AM   #3
ArmstrongRacing
Data doesn't lie
You can use your current bell housing for any future upgrades. You only need to change the output shaft bearing from the 33mm to the 40mm. Then use the rest of the C56 or C60 parts(and axles unless you use a Yaris C50 diff).
Old 04-12-2020, 11:24 AM   #4
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
so in theory...I can take a tercel 150 bell and bolt it to a 4.31 scion c5x trans?
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 04-16-2020, 08:02 AM   #5
remcafee
How much to build me an lsd trans for my 07 Liftback? I prefer to keep it the stock 5 speed
C150 and C50 series ring gear question Ronnie V Performance Modifications 16 03-18-2019 06:14 PM
C150 Vs C54 Parmas Performance Modifications 14 05-14-2010 06:14 PM
