Old 06-16-2019, 11:58 PM   #1
toyotavios_11
Drives: Toyota Vios
Rpm drop fast after letting off throttle pedal
My car is 2007 model sedan with 1NZ-FE mated to U340 4AT.
Recently I notice that when the car is speeding up from 15km/h to 60km/h while the gear is at the point of time in 2nd or 3rd position, the moment I let off the throttle pedal, RPM needle will drop fast from 2000+ RPM to around 1000 RPM then surge a bit up to around 1200 RPM. I can hear there is a minor shock noise from the front and feeling a little bit of jerk.
While the gear is in 4th gear, either lock up or not, letting off the throttle pedal, RPM will just reduce slowly which I feel this is normal.
What are the possibilities of the problem?
toyotavios_11 is offline   Reply With Quote
Successful 1ZZ Throttle Body Swap rabbito Performance Modifications 34 10-15-2024 07:12 AM
HELP: Yaris Matic Idle RPM Drop PlainAndrew DIY / Maintenance / Service 4 07-20-2016 04:04 PM
IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 RPM JEFF Great Lakes 0 09-24-2012 04:40 PM
IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 RPM JEFF Mid-Atlantic 0 09-24-2012 03:10 PM
3 Drive Throttle Contoller by NTD Sabretooth Performance Modifications 31 10-07-2010 12:12 PM
