Old 07-10-2019, 03:06 AM   #1
toyotavios_11
Drives: Toyota Vios
Should crossmember be dropped to replace sway bar bush?
here i mean yaris 2006 model
recently i found that it squeaks loud when go over speed hump so i wish to replace both pieces but i see the space is very compact to let the ratchet to access the sway bar cover bolts
toyotavios_11 is offline   Reply With Quote
Old 08-08-2019, 05:44 AM   #2
toyotavios_11
Drives: Toyota Vios
does anyone know it?
Old 08-08-2019, 07:20 AM   #3
ex-x-fire
I never done one on a yaris, I have on other cars that way. Its your choice if you want an alignment or not.
Old 08-08-2019, 10:40 AM   #4
I'd recommend it to avoid stripped bolt heads. Alternatively you can try without removing the subframe.first and if it doesnt work, then go and lower it.
Old 08-09-2019, 11:53 PM   #5
toyotavios_11
Drives: Toyota Vios
today i remove front tire and have better view on sway bar bush bracket bolts. i conclude that to remove the bolts you have to drop the crossmember.
2005 echo sway replacement sway bar meemadd Performance Modifications 7 08-15-2016 11:56 PM
DIY: Rear shock, sway bar, and strut brace refit Tapokata DIY / Maintenance / Service 19 05-31-2016 01:05 AM
WTB: Weapon R Dragon Intake and TRD rear sway bar. TerenceCruz Willing to Buy by private party 2 07-28-2013 05:13 PM
sway bar links contd jstantherprsn Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 03-26-2011 02:58 PM
Sway bar and struts DOMAV Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-17-2009 02:26 AM
