#1 |
![]() ![]() Drives: 07 Yaris 3DR Join Date: Apr 2007
2007 Liftback Lock jammed
Hi all,
The actual push button/lock part of my liftback is stuck/jammed so I am no longer able to get into the back of my Yaris. I took the rear panel off the inside of the liftback and I have to crawl back there and manually open it from the inside. I'm having a hard time finding a parts diagram for this back panel to figure out which part I need to order so I can fix this. The actuator seems to be working, just the lock itself seems to be screwed. Anyone have a site with a diagram so I can find out which part to order? I've looked around on the parts websites I am familiar with but I can't find it. Thanks! |
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015 Join Date: Mar 2012
http://www.japan-parts.eu/toyota/us/...or-lock-handle
http://www.japan-parts.eu/toyota/us/...k-cylinder-set
Yaris Hybrid Limited 2015 C-HR 1,8 Hybrid premium 2020 |
#3 | |
#4 |
![]() Drives: 2010 Yaris LB Join Date: Jan 2019
Have you tried squirting some lock lubricant in it, such as Lock-Ease?
Do you have power locks? If so, can you lock and unlock it with the lock button in the driver's door or on the key? |
| WTB: 08 Liftback Rear Lock Assembly - Not Lock Cylinder | dbrear | Willing to Buy by private party | 2 | 10-06-2015 08:23 PM |
| Liftback power lock not working | stubbs157 | DIY / Maintenance / Service | 5 | 02-20-2013 09:17 AM |
| 2007 Yaris Door Lock Issue | bhola | General Yaris / Vitz Discussion | 7 | 10-05-2010 12:01 AM |
