Old 08-11-2019, 08:38 PM   #1
Toolaholic
Drives: Olive yaris,FRS, Dakota R/T
Replacing intake manifold gasket
I changed the intake manifold gasket on my 2007 Yaris. It was relatively easy . I took some pics.
Toolaholic is offline   Reply With Quote
Old 08-11-2019, 08:44 PM   #2
Toolaholic
I drained the coolant from water pump lower hose.
File Type: jpeg F6905169-84F4-4158-9150-3C8193B25D55.jpeg (326.3 KB, 87 views)
Old 08-11-2019, 09:06 PM   #3
Toolaholic
I removed air hose between throttle body and filter box and disconnected vacuum lines and radiator cap pipe from throttle body. All bolts and clamps were 10mm
File Type: jpeg AEAFFF97-F3E5-4C80-AE0F-116762A28ABC.jpeg (267.3 KB, 87 views)
Old 08-11-2019, 09:13 PM   #4
Toolaholic
Wiring housing needs removed. Your can see the 12mm intake manifold bolts .
File Type: jpeg 5A1B55D5-4114-40E7-92A2-12758CD546E1.jpeg (263.5 KB, 86 views)
Old 08-11-2019, 09:25 PM   #5
Toolaholic
The spec for intake is 30nm. I tested it with a torque wrench before removal. It clicked and fasteners didn’t move . If the intake fastener moved spec would be lower. I got spec from English Haynes manual . I used a matco 8 inch long 1/4 drive ratchet . It worked but if I do it again I’m using my 11 inch long Armstrong 3/8. Thottle body wouldn’t come off. I moved intake forward skipped out old gasket and put new one in. Note old gasket was oily .
File Type: jpeg 9BF1D91C-924B-42F7-B699-EB9BAFF8065F.jpeg (401.4 KB, 87 views)
Old 08-11-2019, 09:40 PM   #6
Toolaholic
Put everything back together and used lisle funnel to add coolant. Run heater on full blast. Funnel helps burp air out . Note bubbles
File Type: jpeg 813A05B6-694D-4657-BCEC-1220A7C44C95.jpeg (238.0 KB, 88 views)
File Type: jpeg FE82CB01-3B3E-4399-B6D4-9ECD01B47969.jpeg (199.1 KB, 88 views)
Old 08-11-2019, 09:54 PM   #7
Toolaholic
Crappy rusty bent out of shape factory air box hose clamp
File Type: jpeg A9680E0A-CF7B-4804-A1F5-903D6E78A2BF.jpeg (379.8 KB, 85 views)
Old 08-11-2019, 09:56 PM   #8
Toolaholic
New stainless one I installed
File Type: jpeg F529F9C8-19BA-4BE8-997B-542D8482FDE1.jpeg (366.2 KB, 85 views)
Old 08-13-2019, 03:30 PM   #9
seatech30
Drives: Yaris 2008 Sedan
What was the reason/symptoms for changing the gasket? Just curious.
seatech30 is offline   Reply With Quote
Old 08-13-2019, 05:51 PM   #10
Toolaholic
Intermittent misfire cylinder 1. Turned out to be fuel injector . Thought maybe vacuum leak in intake . The gasket was oily so it wasn’t a bad thing. Plus only cost $11 for a fel pro plus some Toyota coolant
Old 08-14-2019, 05:34 AM   #11
toyotavios_11
Drives: Toyota Vios
nice, wish to see anyone can DIY to replace front sway bar bush
toyotavios_11 is offline   Reply With Quote
Micro Image/Golden Eagle Intake Manifold Review tmontague Performance Modifications 18 01-03-2017 08:24 PM
FS: Ported (for 1zz) OEM intake manifold tmontague Items for Sale by private party 6 04-01-2016 11:25 PM
JB Weld stock intake manifold port w/ 1ZZ Throttle Body tmontague Performance Modifications 2 10-07-2015 09:31 PM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 08:03 PM
