Old 09-23-2019, 06:10 PM   #1
steelvulture
Drives: 2012 Yaris
Serpentine Belt Slips When Wet
2012 with 44k miles and still the original belt that came with the car.
With the recent heavy rains here, it seems that the belt is slipping when hitting puddles and getting water into the engine compartment. The charging warning light comes on and the ac compressor stops running (warm air starts coming through the vents). There is also some squealing that can be heard. If I don't hit any more water, the belt eventually catches with the squealing and the charging warning light goes away.
When dry, there are no problems or squealing sounds even with a cold start.
Is all that needs to be done is get the belt replaced?
steelvulture is offline   Reply With Quote
Old 09-23-2019, 06:38 PM   #2
Brighton
Knower of little
Drives: None
Replace it, it's probably dry rotting or is already. Mileage is only part of the equation for life expectancy of perishable parts.
Brighton is offline   Reply With Quote
Determining proper tension for new serpentine belt RMcG DIY / Maintenance / Service 11 12-30-2021 06:01 AM
Which serpentine belt? courtartanis DIY / Maintenance / Service 0 11-30-2017 10:32 AM
Blitz Supercharger Belt Slip @ Higher RPM? Freestylin Forced Induction Forum 20 09-06-2017 07:32 AM
Squeal from Engine after replacing Water Pump and Serpentine Belt vidfan DIY / Maintenance / Service 7 06-24-2014 10:41 AM
Lost Serpentine Belt NickNickNick DIY / Maintenance / Service 33 07-31-2011 12:28 PM
