Old 10-30-2019, 08:31 AM   #1
Cartel
Cartel's Avatar
Drives: 2007 Yaris Hatch is sold
Exclamation 2007 Yaris Charge voltage too low, tried everything
My alternator has been giving me trouble and has a low charge voltage.
I took it apart and cleaned the regulator, checked the brushes and cleaned up the commutator and it all looks good (60,000KM).
The problem is it only charges at 13.6v-13.8v with nothing on while another identical car charges at 14.2v-14.4v.
I checked for voltage drop at full load (130mv) positive and negative (0.001mv) and AC (0mv)
I think my audio amp may have hurt it somehow. (guessing)
I am looking for a heavy duty alternator if possible or I guess I'm going to replace the regulator and see if that helps.
Could the ECM be damaged somehow?
I can find my alternator (27060-21150):
But I also see one with a bigger heat-sink on the regulator and a bigger body too:
Is there a better version?
These both say 80 amps but 1 looks much beefier.
My audio amplifier only uses 40 amps.
Thanks
Cartel is offline   Reply With Quote
Old 10-30-2019, 11:07 AM   #2
Toolaholic
Drives: Olive yaris,FRS, Dakota R/T
I had chestnut hill electric in Denver pa rebuild mine for $108. New bearing , voltage regulator and brushes.
Toolaholic is offline   Reply With Quote
Old 10-30-2019, 01:00 PM   #3
Cartel
Cartel's Avatar
I took mine to the shop and they tested it, it 80+ amps at 13.5 they said no problem.
Its just that the ECM is throttling the voltage back or something.
Maybe someones run into this before?
Old 10-31-2019, 06:17 PM   #4
Cartel
Cartel's Avatar
I notice the idle doesn't go up when I put the heater fan on.
Maybe the sense chip in the regulator is dead?
The A/C amplifier toast?
Anyone seen this issue?
Old 11-03-2019, 08:04 AM   #5
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
The internal voltage regulator is a common failure point as the contacts corrode due to water ingress. One of my Yari runs at ~ 13.8 - 13.9 and the other ~14.2 - 14.4. Both have passed voltage drop tests and neither have any driveability or starting problems. I too looked at an upgraded alternator as I was adding some additional electronics (stereo with amp 75w x 4 and NVX 8" powered sub etc), but the stock 80 amp alternator has proved more than capable of handling the power demands. I think the upgraded alternator I was looking at was 120A. Since your alternator tested good and you don't have a flickering or steady battery light on in the instrument cluster, you're probably fine. Then again, if you drive your amp hard, an upgrade might be a good option.
Here is an upgraded 145 amp alternator for 06 - 14:
https://www.ebay.com/itm/High-Output...cAAOSwI4xa4l9L
Vacationed in Italy - Brought home a D4D diesel Yaris CTScott Photo-Video-Media Gallery 19 07-26-2012 03:13 AM
