Old 01-16-2020, 08:19 PM   #1
remcafee
HELP! P0101 CEL
Anyone here have an injen intake on their yaris and having issues with p0101? surely i cant be the only one. im about ready to drive off a cliff with my car if i cant figure it out. HELP!
Old 01-17-2020, 09:42 AM   #2
What is the inside diameter of the portion of the intake tube where the MAF is mounted? Common cause for throwing this code is people using an intake which is too large in diameter causing out of spec rate of airflow.
Old 01-17-2020, 03:58 PM   #3
remcafee
I believe it’s 2 inch diameter, I wish I can know anyone else who has this intake has the same issue or not
Old 01-17-2020, 07:16 PM   #4
myfirstyota
3 Yaris and counting..
I'm sure many people have had that intake. Problem is no one beyond the dozen or so active members comes here anymore.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Old 03-06-2020, 10:05 AM   #5
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
I was actually looking for an intake, as next performance gain.
maybe not the Injen I take it.
Old 03-06-2020, 02:55 PM   #6
remcafee
Yeah idk why it is has issues, I ended up getting an aem instead and it works fine now
CEL afer oil pressure light andysong DIY / Maintenance / Service 8 03-06-2020 02:57 PM
Injen intake, CEL P0101 remcafee Performance Modifications 3 03-06-2020 02:52 PM
AFE Intake 2008 Yaris CEL Problem (Spacers) LightDisc Performance Modifications 1 04-18-2018 06:26 AM
New aFe CAI = CEL with P0101 Error randydid Third Gen Yaris General Discussion 10 01-16-2012 10:24 PM
AFE Intake cel rihdrkc Performance Modifications 11 01-09-2012 03:23 PM
