Old 06-22-2020, 04:16 PM   #1
maxifam
Drives: Yaris 2010 sedan
Manual door locks
Hello. I bought a used 2010 base model
Yaris 4 door sedan. Love the car already. BUT. It has no power locks or windows, which is fine. There are keyholes on both front drivers and passenger handles, to open the car. But none on the rear doors, so in order to open them, you have to reach in sideways and push on the inside handle lock button to open. Very annoying to have to do this all around the car wehn people want to open all 4 doors. Is this how it works, or am I missing a master button or setting somewhere. I've always had cars with power locks so I'm not used to this. Any info would be appreciated.
maxifam is offline   Reply With Quote
Old 06-22-2020, 05:10 PM   #2
Insert key in driver's side lock. Turn to the right once to unlock that door, turn to the right twice to unlock all doors.
Old 06-22-2020, 05:14 PM   #3
maxifam
But they are not power locks. If I just turn to the right once, and then go back to the left to turn to the right again, it just locks and unlocks again.
Old 06-23-2020, 09:48 AM   #4
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I think you're stuck with the inconvenience. =(
I recently took the doors off a sedan with manual locks. You'd need to replace the latch mechanism, add wire harnesses inside the doors, change the switch assembly on the driver's door and add the button to the e-brake area. Not sure if there's other changes at the junction or relay panels but that's also a possibility.
Old 06-29-2020, 01:32 AM   #5
A lot of people use those cheap $25 to $40 USD door lock actuator kits on amazon. You might want to look them up there. Shouldn't be too hard to install. I don't think you'll have factory options, like one press of the unlock button only unlocks the driver's door. Power locks would only work with the fob too, but you can wire up an interior switch to some of those kits. I think it's all or nothing. Sounds like it that won't really matter to you though.
Old 06-30-2020, 07:48 PM   #6
Ranger SVO
Drives: 2010 Yaris
Using one of those Universal Lock kits on Amazon would be difficult to install on the Yaris and even harder to make it reliable. Forget it. If you don't believe me pull a door panel off and look.
My 2010 Yaris is a base model. I bought my factory lock motors from a local wrecking yard. I bought the rear hatch lock motor from a member here enviri many years ago (2012 or 2013 I don't remember).
I hooked everything up to my alarm/remote start. No button inside.
The moving power of mathematical invention is not reasoning but imagination.
Augustus de Morgan
Truth does not change because it is, or is not, believed by a majority of the people.
Giordano Bruno
Ranger SVO is offline   Reply With Quote
Remote Start DIY Wiring Guide 2006-2010 Yaris CTScott DIY / Maintenance / Service 272 01-22-2022 10:02 PM
Manual are a dying breed. junorico24 Off-topic / Other Cars / Everything else Discussions 17 01-09-2020 10:47 AM
Where to buy service & repair manual? (and Parts manual?) 2010 Yaris Sedan TYaris2010 DIY / Maintenance / Service 1 07-08-2018 09:38 AM
Grimmspeed Manual Boost Controller For Sale fnkngrv Items for Sale by private party 1 05-05-2014 01:25 PM
For Sale: 1993 Honda Civic Si 2dr Hatchback 5sp Manual Effizienz Cars for Sale by private party 9 01-17-2012 11:08 AM
