Old 07-24-2020, 09:32 PM   #1
mtshum
mtshum's Avatar
Drives: Echo RS
What’s this plug for?
Anyone know what’s this plug for?
File Type: jpeg 06280762-9E8C-41DE-B59B-130D1B50C2B3.jpeg (197.6 KB, 100 views)
mtshum is offline   Reply With Quote
Old 07-24-2020, 10:57 PM   #2
ex-x-fire
Looks like a drain plug for the differential portion of the automatic trans. Some Toyotas had check plugs too.
Old 07-24-2020, 11:07 PM   #3
mtshum
mtshum's Avatar
Drives: Echo RS
Do I have to open this drain plug too?
Old 07-25-2020, 12:07 AM   #4
ex-x-fire
I was searching for an answer, I haven't found one yet. I guess if you do drain it there, make sure theres atf behind that plug, when you fill it through the trans dipstick tube.
Old 07-29-2020, 11:03 PM   #5
alanwagen
Leave it alone unless you are ready to change your transmission fluid which can be tricky as the procedure has to do with oil temperature.
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 02:12 PM
Wires Inside the Yaris & What They Do The Architect DIY / Maintenance / Service 149 10-18-2022 03:32 AM
bit of spark plug insulation may have fallen into cylinder alagappan the proud DIY / Maintenance / Service 20 01-09-2014 06:10 PM
Function of square plug near 12v. plug! RS-Yaris General Yaris / Vitz Discussion 2 11-22-2011 08:16 PM
Plug Gap slvryaris DIY / Maintenance / Service 1 12-23-2008 10:02 PM
