Old 07-29-2020, 08:01 PM   #1
andulong
andulong's Avatar
Drives: 2008 Hatch Red
Headlight adjuster (not adjustment)
Hi Everybody,
Been loving my Yaris for years and it is still going strong. Yesterday replaced the headlights and upon re-assembly found out that the passenger side headlight was not securely in place. I noticed that when I grabbed the socket/plug I could easily move the inner assembly up and down. I then saw that the adjuster was freely moving in and out and not holding things in place.
I popped the adjuster off to look at it and have not tried to open it up yet. But am guessing it has worn or stripped threads or gears inside of it allowing it to easily slide inside itself with out turning.
I thought, no problem I will go online and order one and it will be a simple fix. Well it appears that they do not sell these separate from the headlight assemblies. I was hoping someone here might know of a source to get just this part. If not I will be trying to open it up and find a fix. Maybe someone has already dealt with this problem and has a simple fix.
Thanks!
andulong is offline   Reply With Quote
Hatchback Headlight adjustment Hoagie DIY / Maintenance / Service 1 03-20-2018 06:03 PM
cant find the horizontal adjustment screw for headlight hatchback.. marcus Cosmetic Modifications (Exterior/Interior) 18 02-01-2017 03:26 AM
diy HID projector w/ halo headlight install tmontague DIY / Maintenance / Service 17 02-04-2016 11:34 AM
2009 Hatchback Headlight level adjustment 12secondscooby DIY / Maintenance / Service 10 02-19-2014 06:54 PM
Headlight adjustment screw question. evan DIY / Maintenance / Service 6 01-09-2009 05:58 PM
